Thanks a lot for your help and comments. I was ill. Now I am good, but...HEEELP! HEEEELP!!!!.
It seems that I have erased the data inside the Dallas Watchdog timer chip. I wanted to try my dexterity with the Dremel, and everything went well. I found a couple of 3V batteries inside (one of them with 2.9V, and the another with 2.7V...no need to change, but...lithium, ya know...suddenly zero...or very close to). The thing is I am sure I did not damage any internal part. But I am sure that I disconnect one of the batteries with the Dremel (the negative pin) before applying new battery (a 2,300 mA one...). The secondary battery was fine, untouched and connected (I mean here the one which is deeper, the one which is mounted farther from the pin #1).
I socketed the 3 main ICs (EPROM and the two Dallas chips). I have do it so to buy a programmer and extract its contents, specially for TERRA Operative (he told me so). I tested the scope with the new sockets and it worked as ever. Perfect, no problems at all. BUT when I make the change of batteries in the Dallas DS1486-120 chip, connected to the socket in the scope, and turned it on...everything seems fine (video tests on screen, relay clicks, etc.), the scope is stuck in the clock!!!. I am not able to boot it up again!!!
and I cutted the negative from the second battery once I connected the new one (see pic).
So...what can I do?. Of course, it seems to be very clear that my problem is in the above mentioned Dallas chip (I thought it has no data inside, only realtime clock), but obviously it had data.
BTW, please tell me what programmer I can buy to work with these chips, and also to extract the data from the EPROM, and the program to work with it (maybe the programmer comes with one).
Please, I need your help. I know that I will have it.
Here are some pics of the results. I needed to connect both positive terminals of both batteries, because connecting the new one to the one closest to pin #1 does not make that the second battery inside the Dallas to have voltage (maybe a diode between the two?...if so, I did not use a diode...hope this will help).
Thank you all.
