ok there is something wrong with my NVram but the error is not fixed with a new 1250Y. there are also problems with my DS1486 and i think the options are inside there... uuhh were inside there. so as a matter a fact after today when i did a extended debug logging after that everything was lost... i did the debugging with (switch 6 and 7 dipped).
after that booting no options anymore...... strangly................. when i dipped 3 ( this short bootup the unit, no long diag) but the scope starts with all options enabled?? this is bit strange for me.
when i run SPC it is passed.
Now i am waiting for my new vp390 programmer to arrive. my TOP853 failed... after verifing my DS1250Y !!
So after the long debugging today all my CALLs are saying "initializing" and NO options are showed anymore..
i did some tests: when i boot my dos computer with GPIB config
i can do a clearerr.exe run what clears the errorlog in my scope -> works perfect!
-> but i can not read nor write the Nvram or flashrom with the tektool ?? -> doesn t work !
i waited for 1 hour and nothing happens ..yes yes i flipped the write protection switch.
ok My logging:
RUNNING FROM DRAM.
DRAM test passed.
Bootrom Header Checksum passed.
Bootrom Total Checksum passed.
BootRom Check Sum passed.
Bus Error Timeout test passed.
Kernel Diagnostics Complete.
Calling SDM (monitor) Routine.
Enabling Bus Control register. Value = 0x67
IMR 1 Register test passed.
Misc. Register test passed.
Timer Interrupt test (Auto-Vector) passed.
NVRam DSACK test passed.
NVRam Write protected.
Flashrom DSACK and JumpCode test passed.
Flashrom Checksums passed.
Bootrom Diagnostics Complete.
DipSwitchValue: 60
Skipping boot loader.
Transferring control to FlashROM.
No PCMCIA option board detected.
FLOPPY: Detected
No ZIP/ZIPplus detected
Adding 7165 symbols for standalone.
CPU: 68EC040. Processor #0.
Memory Size: 0x1000000. BSP version 1.0.
Executing Diagnostics
-> ERRORID: 358 nv storage too small more bytes requested than available
ERRORID: 163 diagnostic test failure Start Power-On Sequence
Start Power-On Diag Sequence
hwAccountant probe routines
Probe for unexpected pending ints
Dsp Instr mem size
Dsp D2 mem size
Dsp D1 mem size
Dsy Vect0 mem size
Dsy Vect1 mem size
Dsy Wfm0 mem size
Dsy Wfm1 mem size
Dsy Text0 mem size
Dsy Text1 mem size
Acq number of digitizers
Acq mem size
Cpu timer interval uSec
Cpu Dram size
NvRam mem size
Limit to 1GS/sec presence
Opt Math Package presence
Opt Telecom Masks presence
Opt 3C presence
Opt 4C presence
Opt RS232/ Cent presence
Opt 1M presence
Opt 2M presence
Acq Intlv Cal Id presence
Opt TvTrig presence
Opt TvTrig index
Dsy color presence
Opt floppy drive presence
Opt hard drive presence
Acq number of user channels
dspForcedBus ................... pass
cpuDiagD2MiscReg ............... pass
cpuDiagDSPIntMaskReg ........... pass
cpuDiagD1D2Access .............. pass
cpuDiagDsyAccess ............... pass
dsp68kMemTest .................. pass
cpuDiagFIFOMem ................. pass
dspRunVerify ................... pass
dspBusRequestTest .............. pass
dspImplicitBusAccess ........... pass
dspTristarMemTest .............. pass
dsyDiagPM100Reg ................ pass
dsyPM011RegMem ................. pass
dsyLCSRamdacRegMem ............. pass
dsyMonoRamdacRegMem ............ UNTESTED
dsyVGARamdacRegMem ............. pass
dsyDiagPPRegMem ................ pass
dsyDiagRasRegMem ............... pass
dsyDiagAllMem .................. pass
dsyDiagRegSelect ............... pass
dsyDiagRandDotMode ............. pass
dsySeqYTModeV0Intens ........... pass
dsySeqYTModeV1Intens ........... pass
dsySeqYTModeV1Attrib ........... pass
dsySeqYTModeV0Clip ............. pass
dsyDiagSeqXYModeV1 ............. pass
dsyDiagDecayMode ............... pass
dsyRastModeV0Walk .............. pass
dsyRastModeV1Walk .............. pass
dsyRastModeV1Attrib ............ pass
dsyWaitClock ................... pass
dsySplashScreen ................ pass
cpuDiagAllInts ................. pass
nvLibrariansDiag ............... ***FAIL***
..error details:
ERRORID: 163 diagnostic test failure nvLibrariansDiag
Libs with crcc failures:
ExtConst
calLibrarianDefaultCk .......... ***FAIL***
..error details:
ERRORID: 163 diagnostic test failure calLibrarianDefaultCk
Libs set to factory defaults:
PFCal-3C-P6701B, PFCal-4C-P6703B
acqProcThermistor .............. pass
twoGHz50OhmOvldConf ............ UNTESTED
trigGtlRegisterDiag ............ pass
trigBtlRegisterDiag ............ pass
ch1LogicTypeComp ............... pass
ch2LogicTypeComp ............... pass
ch3LogicTypeComp ............... pass
ch4LogicTypeComp ............... pass
ch1EdgeTrigDiag ................ pass
lineTrigDiag ................... pass
dlyTrigDBETrigAfter ............ pass
dlyTrigDBTRunsAfter ............ pass
slewrateTrigDiag ............... pass
trigAttenSerialReg ............. pass
trigPreampSerialReg ............ pass
trigDTCSerialReg ............... pass
trigExtlSerialReg .............. pass
trigDacSerialReg ............... pass
TICountersDiag ................. pass
gtlBigCountersDiag ............. pass
trigBtlConfidenceDiag .......... pass
trigGtlCompRamDiag ............. pass
digRegisterConf ................ pass
digDataFormatConf .............. pass
digSpeedMemConf ................ pass
digAcqSubSampleConf ............ pass
digAcqPeakDetectConf ........... pass
digAcqHiResConf ................ pass
digAcqMemDataConf .............. pass
digAcqMemAddrConf .............. pass
digInterruptConf ............... pass
digA2DConnectsConf ............. pass
digHFStepConf .................. pass
glitchTrigDiag ................. pass
pulseWidthDiag ................. pass
trigNibDiag .................... pass
digInstaVuXYConf ............... pass
fpDiagConf ..................... pass
optDiagPM110Reg ................ pass
optDiagFloppyCacheMem .......... pass
optDiagFloppyControllerIO ......0x5fffe80 (tRootTask): libError 358, lib EXTCAL, id=358, msg=more bytes requested than available
pass
optDiagFloppyDrive ............. UNTESTED
optRS232DuartIO ................ pass
optRS232DuartIntLoop ........... pass
optCentronCntrlReg ............. pass
optTv8bitRegDiag ............... UNTESTED
optTvShiftRegDiag .............. UNTESTED
optTvXparentCodes .............. UNTESTED
optTvDontCareCodes ............. UNTESTED
optTvEdgeAndLevel .............. UNTESTED
optTvSyncLevels ................ UNTESTED
ERRORID: 163 diagnostic test failure **Error count in 1 pu_diag seq passes:
ERRORID: 163 diagnostic test failure .. 1 = Processor
ERRORID: 163 diagnostic test failure .. 1 = Cal Initialization (see error log)
ERRORID: 163 diagnostic test failure thermistor = 118
Executing Smalltalk
Dsp Instr mem size
Dsp D2 mem size
Dsp D1 mem size
Dsy Vect0 mem size
Dsy Vect1 mem size
Dsy Wfm0 mem size
Dsy Wfm1 mem size
Dsy Text0 mem size
Dsy Text1 mem size
Acq mem size
Cpu Dram size
NvRam mem size
Opt 3C presence
Opt 4C presence
Opt 1M presence
Opt 2M presence
Opt TvTrig presence
Opt TvTrig index
Dsy color presence
Smalltalk/V Sun Version 1.12
Copyright (C) 1990 Object Technology International Inc.
ERRORID: 163 diagnostic test failure extended cal librarian reset
loop 8, .25 > TI value > 3.75
