Author Topic: Termocouple data logger multi-channel (Low cost)  (Read 1355 times)
Offline JesterTopic starter
« on: October 26, 2018, 02:05:52 pm »
I'm doing some temperature testing and would prefer to have the measurements recorded automatically.
This device seems to have the basic capability, however it uses DS18B20 sensors which are less than ideal when probing small devices on a PCB. I would prefer something similar however with standard type K thermocouple connectors, as I have plenty of them.
https://www.ebay.com/itm/Temperature-Data-Logger-to-PC-4-Channel-COM-via-RS-232-No-Sensor-Version-CH015/291295206468?hash=item43d28c1c44:rk:1:pf:0
This device accepts regular thermocouple inputs, however it does not log directly to a PC, you have to let it capture and then connect and download data, and max time to auto off is 90 minutes also less than ideal.
https://www.ebay.com/itm/UEI-DT304-Apollo-IV-4-Temperature-Logger/323474622332
So is anyone aware of a low cost multi-channel thermocouple data logger that accepts regular thermocouple connectors and logs continuously to either a terminal program or whatever software comes with the device?
Thanks
