Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14961634 times)
powerflux, binary01 and 248 Guests are viewing this topic.
« Reply #102375 on: September 20, 2021, 02:54:59 am »
Ifni save me... I'm going there.
I hope it works after all that effort.  :scared:
In all honesty, fixing the optical assy mechanicals is the most fun I've had in weeks.  :-DD  This tedious micro-bodgery is the only part of it that feels like actual work;)
*tssssst...*
« Last Edit: September 20, 2021, 02:57:43 am by mnementh »
Offline 0culus
« Reply #102376 on: September 20, 2021, 03:15:12 am »
I had gathered by now that Saskia was a she. Mansaxel is too then ?! So that's too girls on a nerdy forum, I am impressed. Any other girl on TEA ? BU ? BD ? Specmaster ? Zucca ?  Don't be shy...
I identify as an attack helicopter.
The following users thanked this post: Vince, mnementh, Specmaster, capt bullshot, bd139, ch_scr, factory
« Reply #102377 on: September 20, 2021, 04:45:59 am »
*tssssst...*
Microbodgery done; continuity exactly where I expect it and not anywhere else. A couple layers of Kapton to make sure it plays well with the metal chassis of the camera.
Like last time, this is a good place to stop. Next insanity installment tomorrow.  :-+
The following users thanked this post: Specmaster, cyclin_al, BILLPOD, Peter_O
Offline capt bullshot
« Reply #102378 on: September 20, 2021, 05:20:38 am »
And now for something completely different   Fun with TEA!   (SNIP)
Now, I've taken the heat gun and partially warmed the RG174 by maybe 5°C ... 10°C. Result is here:
 There's a change in delay of the warmed up RG174 line of about 2.5ps within 12sec.
And the Capt'n is impressively far in already, mind! I have tried to build something comperable twice now, with the experiment (as shown) the significant "is it good enough" test. And whilst twice I insisted on unconventional methods (by building from stock my junk box the hoard) and I got closer the second time, twice I failed so far. TL;DR: I am reasonably impressed - my device has noise at least 10 times higher...
I've got another DMTD contraption built with XOR gates (a modification of the one I've shown here some time ago, inspired by your unconventional methods). Its performance is quite similar to this one, for what I've tested up to yesterday. Yes, it's an rabbit hole and Bunny won't get it back soon ...
This stuff enables you to measure e.g. how well your AWG / Signal generators synchronize to the external 10MHz reference. E.g. the Tek AWG is way better to test this than the Anritsu MG3633 SGs, though they're are said famous for their low phase noise. Or, a borrowed HPAK33522B from work: It's slightly better than the Tek here.
« Last Edit: September 20, 2021, 05:39:14 am by capt bullshot »
The following users thanked this post: mnementh, ch_scr, Kosmic, cyclin_al
« Reply #102379 on: September 20, 2021, 05:34:07 am »
Been there, done that - long time ago when I could use my eyes without artificial amplification to do such soldering. Last time I had a broken FPC, luckily some chinese seller offered replacement for little money.
« Reply #102380 on: September 20, 2021, 05:48:26 am »
I've got another DMTD contraption built with XOR gates (inspired by your unconventional methods). Its performance is quite similar to this one, for what I've tested up to yesterday. Yes, it's an rabbit hole and Bunny won't get it back soon ...
Most of this goes comfortably over my head, which is something of a  :scared: :scared: moment -- since I'm supposed to understand at least a little bit about time / frequency transfer. First relevant Google hit on "DMTD" is a MSc thesis from Poland on the White Rabbit network, where clock synchronisation to 1ns is achieved over Synchronous Ethernet, using IEEE1588 Precision Time Protocol. My applications at work have 103 less precision requirements than that.  :phew:
Edit: Swenglish somewhat corrected.
« Reply #102381 on: September 20, 2021, 05:58:32 am »
This one gets nearer to what I'm trying to achieve:
http://www.stable32.com/A%20Small%20DMTD%20System.pdf
And there's a thread here on eevblog:
https://www.eevblog.com/forum/metrology/dmtd-board/?all
DMTD typically is all about measuring oscillator stability to ppt (1e-12) or better. The main point is: By mixing the DUT frequency with e.g. a 100Hz (10Hz, 1Hz) offset reference, the errors get multiplied by the ratio of reference to offset frequency (e.g. 100000 for 10Mhz / 100Hz), this way shifting picoseconds into 100's nanoseconds range, which can be easily measured by conventional counters. The TA520 is quite a luxury item here, as its 25ps resolution isn't required at all for these measurements.
The following users thanked this post: mnementh, Neomys Sapiens, ch_scr, mansaxel, Kosmic, cyclin_al
Offline vk6zgo
« Reply #102382 on: September 20, 2021, 06:17:03 am »
Nothing a ham has touched is probably working.
That's not nice of you to say. Most things I've touched were already broken before I repaired them. ;-)
Are you sure you aren't Irish?
The following users thanked this post: mnementh, shakalnokturn
Offline vk6zgo
« Reply #102383 on: September 20, 2021, 06:46:36 am »
Was? Still is as far as I know ...  ::)
"Was" for someone who still "is" is common Australian English usage,--------maybe also French?
Offline dl6lr
« Reply #102384 on: September 20, 2021, 06:54:40 am »
Same in german common speak.
Offline ch_scr
« Reply #102385 on: September 20, 2021, 07:27:58 am »
Just got an email from keysight promoting this playlist on their Youtube channel.
Their pitch: No more secrets! Hear it from the engineers themselves – this is what’s behind the most powerful signal analyzer on the planet.
Also, it allows a look at their facilitys in some of the backgrounds  :scared:
https://www.youtube.com/playlist?list=PL2XuMA5AwNUwm8pKzVQzDGCjrMzdovFyG
Offline Saskia
« Reply #102386 on: September 20, 2021, 09:08:00 am »
No intention of changing that  :-DD :-DD
Here you can find the teddy bear Mnem was talking about ...
Offline Vince
« Reply #102387 on: September 20, 2021, 09:31:11 am »
That's perfectly fine with me, I just love helicopters  8)
Offline Vince
« Reply #102388 on: September 20, 2021, 09:34:20 am »
Yes this is exactly it. We say "was" even if talking to the person in the eye and he/she is very much alive and talking to you !   :-DD
Interesting to know some English speaking countries do the same.. but not all of them.  Makes life more difficult for the foreigner that I am...
And the Germans do it too then... how comes...
« Last Edit: September 20, 2021, 09:45:33 am by Vince »
Offline Vince
« Reply #102389 on: September 20, 2021, 09:34:56 am »
I will never look at my Teddy bear the same way...
« Reply #102390 on: September 20, 2021, 09:42:38 am »
I hope not. We need someone around here to clean the place and cook the meals.   >:D
J/K.  :P :-DD
Offline nfmax
« Reply #102391 on: September 20, 2021, 10:03:02 am »
But French helicopters go round the wrong way!
The following users thanked this post: mnementh, scl, bd139
« Reply #102392 on: September 20, 2021, 10:05:29 am »
That is a typical Louis Rossman style "bodge"  :palm: >:D
« Reply #102393 on: September 20, 2021, 10:12:55 am »
Bodge or not, don't knock it if it works.  :-//
« Reply #102394 on: September 20, 2021, 10:26:03 am »
Pee Wee Herman is at my local PO to be delivered today.
I hope it hasn't been to any movie theaters lately.  :P :-DD
The following users thanked this post: Cubdriver, mnementh
« Reply #102395 on: September 20, 2021, 10:30:09 am »
Totally agree, I don't have issues with Louis's repairs  ;)
Offline Saskia
« Reply #102396 on: September 20, 2021, 10:43:38 am »
Proposal to develop Insulin sensor submitted to the powers that be.
Now need to forward this to our CEO thru channels just in case some midlevel management critter decides that it's too much work to take a stand ...
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #102397 on: September 20, 2021, 10:58:42 am »
Was, is, and will be!  :clap:
Now about Vince ...  :-//
Offline Vince
« Reply #102398 on: September 20, 2021, 11:01:14 am »
 :-DD
I don't know if there is a right or wrong way, however it is true that the main rotor on French helicopters does turn one direction but helis from the US or other countries rotate in the opposite direction !  :-//
This is less and less true though, since the French helis are now less and less French. The EC135 and 145 IIRC are originally an old German design so their rotor is turning the "right" way. Also, newer designs like the EC175 were co-designed with the Chinese so I suspect it also turns the "right"/"international" way.
As years go by and older French designs get phased out, progressively all French helis will rotate the same direction as the rest of the heli world...
Offline Vince
« Reply #102399 on: September 20, 2021, 11:03:40 am »
Well same for me, was is and will be, hopefully for a few more decades !  :-DD
