-group-therapy-thread/?action=dlattach;attach=1610035;image)
00H50, worked a little bit this evening.
Managed to fix yet another TV / monitor that a friend gave me a few days ago. I think I am getting the hang of it.
Since these things are a pain, crap as fuck and worth nothing... in order to not waste my time and sanity on these things, my method is now well established :
- Pop the rear cover
- Measure voltages. Low voltage going to the digital board, and HV going to the backlight.
- If not good, try to fix it, doing only the easy stuff : buzz diodes and electrolytic caps.
- If voltages are good, remove the LCD screen / filters sandwich, and test the LED strips.
- Bridge any bad LED. Once the screen and diffuser are back in place, you can't even tell if a single, even several, LEDs are not working.
- Test the device... if still not working, give up and scrap for parts.
Doing that, I have managed to fix the 10 or so TV / monitors I was passed, bar the very first one because the screen was already smashed when it was given to me....which I found out only once I had fixed the backlight issue, of course...
So yeah, it's incredible. maybe 10 TV / monitors I was given , all of them had either a power board problem, or dead LEDs. This makes it worth sticking to simple things and give up if it resists, because sticking to the simple/quick stuff fixes so far all of them !
Well, 90% of them.. as I was writing this I now remember one that had a bad chip. Single board and single chip design, big BGA chip that does it all. I think part of it was dead... TV was "working" / alive, menus would display and were working, but it failed to detect any signal on any of the inputs. Since all inputs were wired straight to pins of the chip... I declared that BGA chip Kaput and scrapped the TV.
Anyway, I fixed this one today because it's the kind that I could use in the lab to work on various stuff : not too big, not too small, lightweight, and many types of inputs. Old inputs for when I work on my old junk : VGA, SCART, but also modern stuff like HDMI, USB and some slot to stick some type of extension card into it, not sure what it uses and what you can do with it. Maybe a memory card or some kind of SSD to record programs or whatnot. Don't really care as I doubt I will ever use that feature.
Also comes with its remote, that's convenient. I like the menu system as well, looks nice and user friendly.
Only slight issue is that it's missing its feet. Previous owner I guess mounted it on a wall using the VESA mount. Not too bothered with this since I would probably also use the VESA mount myself. And if not, the bottom of the TV case is actually pretty wide and flat, so it's pretty stable as it is.
Well I had already another TV that I fixed to fill this role in the lab, but I guess you can never have too many options. If one doesn't work, take the other !
This one looks slightly less cheap and ugly than the other one, so that's another reason to keep it around. Would scrap the other one but it's got a video composite input which can be very handy, which is lacking in the TV I fixed today.
Anyway, feels good to fix stuff, even if it's consumer junk. At least I won't have to spend money for TV / monitors to equip my lab, or as a temporary backup if my computer monitor (also one I fixed !
) dies.
So what was wrong with this one then ?
I followed my procedure above.... voltages looked good, but no backlight. Removed the LCD screen, tested the LEDs. There are two strips of x11 LEDs, mounted horizontally and wired in series. Fired up the lab power supply to test them. First strip lit up. Second did not, so I scraped the silk screen at every LED, so I could make contact with them. Only one bad LED, the very last one of the strip. Desoldered it, bridged it with a blob of solder. Works like a charm and once all put back together the eye can't tell the missing LED anyway
Tried it on my TDS 544A scope, works like a charm, mission accomplished
