-group-therapy-thread/?action=dlattach;attach=1749941;image)
Say hi to my new friend !
He popped up on Leboncoin.fr a few days ago, just received it this evening.
Another Rochar Nixie meter, my 5th one now, this time it's a type A.1613
SPECSUnlike my other Rochar meters that do just this or just that... this one does it all, a true DMM : does V and A both DC and AC, does resistance and capacitance.
It's also very compact indeed, so all in all it ticks all the boxes to be used often on the bench
4 digits, 2,000 counts.
Goes up to 1,000V Vdc which will be perfect to check the B+ voltages when fixing my hollow-state Tek scopes.
Can go down to 0.1mV resolution on its 200m range, so it will be able to check ripple voltage as well.
Capacitance range only goes to 1uF but goes down to 200.0pF so 0.1pF resolution which is excellent.
I mean as much as I love my collection of fancy Metrix MX53/54/56 handheld DMM, they couldn't measure anything below 1 or 2nF to save their lives.
It has the printer output option !
Came with the original power cord... that can plug into that long obsolete power socket. Great, ready to go
Oh, and 100% discrete transistors, zero IC. A mix of Germanium and Silicon trannystors.
I spotted some 2N2905 on the PSU board. I think all the Germanium ones must be on the display boards.
As usual with Rochar, following their take-over by Schlumberger, this meter was also available under the Schlumberger or Solartron badge. Only the colour of the face plate changed. My Rochar is dark grey which I love, but was also apparently available in "chocolate". A different model year / face lift I guess. Schlumberger was purple, and Solartron, the usual beige.
Oh ! One odd thing about this meter... It's got 3 input jacks : a common negative, a positive for V/A/ohms, and the third jack is used solely for capacitance
measurements. Well, believe it or not, but the common ground is... RED, and the positive jack for V/A/ohms is BLACK ! How twisted is that !
No, nobody messed with the jacks... I checked several pictures of that meter on the web, and they were all like that !
COSMETICSOverall like new inside out, like fresh from the factory. Only problem is the enclosure. It's a one piece plastic part, Bakelite. Up close it does not look nor feel as"cheap" as I feared it might, so I am good with that. Problem is that it's brittle of course, and the top left rear corner is broken, a good chunk parted with the instrument. Also, there are paint chips all over the edges. Paint is also impossible to clean because the Bakelite is textured.
The display bezel = same causes same consequences...
So at some point I will reconstruct the broken corner, strip the paint (with chemicals not by sanding, to conserve the texture/grain...), fill all the dents/nicks that need filling, and repaint it... maybe satin black, or pink with yellow and lime green stripes, no sure.
Also, the 5 tiny Philips self taper screws that hold the face plate to the Bakelite case... one of them jumped under the bench, it's gone for good. 2 other screws are turning round and round... stripped "thread". The last 2 screws are good for now but for how long.
All my Rochar TE have these crappy screws that drive me nuts and cause nothing but problems.
So I need to come up with something... maybe enlarge the holes in the Bakelite, fit metal thread inserts and use machine screws instead. They actually did jsut that for the 2 bottoms screws at the rear of the unit, that secure the chassis to the enclosure. That would solve the "reliability" issue, as well as give me a lot of choice regarding the style of head, and finish.
ELECTRICALSAs I said it's like new in there, but it has issues nonetheless.
It mostly "works", but needs fixing. Unusable as is. It's got an unacceptable zero offset issue, plus the measurements are very unstable, never twice the same reading. If you average the values in your head, and take into account the offset, I would say that it basically works in all functions and ranges, and the average value is not far off the expected value, say -10% off max, and it jumps around this value by maybe +/- 5% or something.
Problem is that I can't find a service manual for this particular meter. If you find one... I mean for free or not, gimme a call...
"Luckily" Rochar was short lived, I mean design-wise all their meters were roughly from the same technological era, so same engineering solutions across their TE. Just looking at it I can see that the guts / core of the instrument are similar to my other Rochar TE. So I have some idea of what might be wrong, but still, without a manual, I could be working on this thing for 25 years.
CONCLUSIONOverall, extremely happy with my purchase (60 Euros, the top end of my "impulse buy budget"....).
Featureful yet compact meter, looks super cute, excellent nick inside out, mostly works... it sure is well worth fixing the electrical issues and refurbishing the Bakelite enclosure / display bezel.
So I have now 5 Rochar TE, one counter that's like new and works perfectly without me even opening it.... the remaining 4 are all voltmeters or volts/am-meters that need electrical troubleshooting... but they are resisting me big time.
The good news is that I actually have a hope of fixing them... because I took the decision for the next 12 months to take it easy on the construction of the garage/workshop, for money reasons. Instead, I have decided to work on the lab : downsize, make room, keep only the old TE that I really value most, and freaking FIX THEM so I can actually put them back together and USE them at long last, have some fun with them.
