Oh, something out of the ordinary just popped up here.
https://www.leboncoin.fr/cd_musique/2347368439.htm
A Neek-c clock. I mean, an actual one from back in the day.
Looks like a commercial kit unit to me. Cabinet wood work looks home made.
I don't know who is the manufacturer of this one. In the bottom left it says " PB DU1 ".
Maybe "PB" is the manufacturer and " DU1 " the model number...
Not for me and way too expensive, but if someone wants it I can be the middle man.
I doubt that's commercial. The alignment of the 5 LED's above "No touch" is terrible. Also, at what time were there commercial units that used Nixie tubes and LED's at the same time? That's two completely different era's.
McBryce.
They look like neon bulbs to me, not LEDs.
But nevertheless I think you are right. Didn't notice the misalignment of these holes, bit odd indeed. so I zoomed on the picture and found other clues that holes and cutouts were done by hand....
the entire "Sync no touch ! "area of the front panel is odd for a commercial product. The tiny galvanomter to check battery voltage is a bit "too much"...
I got fooled a tfirst glance because of the engraved alu face plate that looks professional at first glance... but the cabinet clearly was home made. Hence my assumption it must have been a kit.
But yeah the more I look at it, the more it seems like a one-off home made project. Some guy tried to make vintage looking clock and overdid it....
The face plate either he spent an arm to get it done but could not afford the drilling and cutouts so had to do it himself, or the machine he had access to could only do the engraving but not the drilling.
Maybe he had access to a machine at work to get it done for free, or got a cheap hobby milling machine that could engrave but did not have the tools or grunt to do the cutouts and drillings.
He went to the trouble of fitting an obsolete '60s style power socket at the back, which helped in fooling me as well...
As for the " PB DU1 "marking iun the lower left corner, I guess he just made that up. I mean Google fails to find anything about this.
OK so it was just someone having fun doing a Nixie clock project, it looks like. Would help if we had pics of the insides of course, that would be a give away !
Still, was interesting seeing this thing listed, was out of the ordinary.
