I knew that would upset someone!
There was no smoke, but it did absolutely nothing apart from push one side high and the other low. More than likely a misplaced connection, but there's work tomorrow morning, so I'll have to debug tomorrow.
Good luck. I would test each section at a time, starting with the oscillators, then the integrators, then the quadrature oscillator. Then the summing amps.
It pulled around 3-5mA per rail according to my power supplies when it was working - worth comparing against that.
tggzzz: The original was on solderless board as well. And it had a note saying "only to annoy tggzzz"
More solderless board fun to annoy tggzzz. Testing tunnel diodes out of that 475A. All test good.
Poor man's curve tracer. 33120A as curve source, scope ch1 as voltage (measuring voltage across D), ch2 as current (measuring voltage across R). Don't do this with a ground referenced function generator - won't work! Has to be floating, one reason I bought the thing!
Now for a tunnel diode output. This is why these things are rather cool. Notice the "blank" spot which is a zone of negative resistance.
And a 1N4148 just for fun.
