Yes, in principle you have exactly the same thing with any mobile phone... but you can turn that OFF.
Not without removing the battery can you certain that it is not recording you, the same with the microphone in a laptop or even for that matter the microphone on your landline phone, in your car or even on your webcam for instance, to be 100% certain you need to disconnect the microphones from any power source.
That's not what I meant. I meant that you can turn those "services" off.
...There are a lot of safeguards being forced on phone manufacturers to make it so you have to opt-in to such services. Once you accept the TOS of a prepackaged surveillance device, you can't undo it. Even if you try, there's a record of you at some point accepting those terms which can always be used against you.
There is a lot of anti-big-brother activity on both the PC and smartphone front; lots of folks who know what they're doing have made software that CAN tell you if your device is recording you, and what you can do to turn those "services" off. Yes, in the end you still only have someone else's word for it that you aren't leaking data like a sieve; but if you are, it's a matter of someone else actively engaging in wrongdoing, not you broadcasting the content of a surveillance device across the internet. Don't plug that phone or computer in to charge and take batteries out if you aren't going to use them for a while.
That's a completely different thing from willingly inviting 24/7 surveillance into your home, which no matter what else you call it, that is what a "smart speaker" is: a cleverly marketed surveillance device.
Getting Mr & Mrs Dumbsheep to pay you for the privilege of stealing their privacy is quite the Advertising coup, for sure.
Bottom line is that in this day and age, you can't function without a phone and a computer. I know for a fact you can get very reliable voice recognition from a local machine; I ran my helpdesk for years with
Dragon on a Pentium desktop. There is no need to be doing this over the cloud, period.
Thank you sir, may I have another?
