No, I was just stating the intended design of the original open-source project; it was to convert any of the oodles of clone 937 soldering stations that were well-known to die a fiery death. My intent was to make a station with a boost converter inside that could power the OLED T12 Controller from any 12V-24V DC power source of sufficient current.
I forgot that banggood has a 100-220VAC-24VDC/4A SMPS board that should work with any of these enclosures (US$7-12 Depending on where it's coming from). It has grounded screw hole mounting and fused input, so the non-fused cloverleaf power plug on their extruded AL brick-style enclosure is a non-issue. I've updated the original post with that item as well.
The tooth says WHEEEEE!
THank you for compiling this list for me, its appreciated but I still fear that I cannot use either the case nor the power supply that you suggested because looking at others peoples builds using that combination is just a little to tight for liking internally and of course, it would be nice to standardise the same power leads as everything else, is, that the IEC plug.
The power supply that I already have slides into the 2 cast channels on the side of the case and holds the PCB nicely of the bottom and provides good isolation and is also 83 x 83 so is a good bit shorter than the Banggood one. By rotating the IEC male part of the connector 180 degrees it will me even greater flexibility for positioning of the power supply in the case as it will slide under the IEC connector of I want it to so in reality providing something in the order of 20mm space to play with to avoid putting pressure on the front controller and iron connector.
https://www.aliexpress.com/item/1pcs-lot-injected-mold-table-box-ABS-plastic-enclosure-case-Alumium-alloy-shell-for-electronic-device/32821952541.html?spm=a2g0s.8937460.0.0.wNHqOR
The power supply is also fused and smaller.
https://www.aliexpress.com/item/QUICKO-New-Arrival-T12-Power-Supply-24V-108W-4-5A-for-OLED-LED-soldering-station-DIY/32834572016.html?spm=a2g0s.8937460.0.0.wNHqOR
You're welcome! I hope this list proves useful to anyone else looking to build one of these.
As with any such project, one person's SOW will differ from another's. Mine concentrates on minimal cash out lay and custom fabbing to achieve a certain form factor; yours clearly prioritizes other things.
When you said IEC, I thought it was the IEC safety rating you wanted, which both receptacles are (IEC C14 vs IEC C6), not a specific IEC standard. Both are pretty common standard cords nowadays, and the IEC C5 cords have an added convenience in that they're usually the much more flexible flat cable w/GND. Of course IEC C13 cords are available in this style as well, but they're not as common.
I also notice that Banggood.com is now offering a "New" version of the OLED T12 controller; it apparently has a clock and battery-maintained memory for multiple iron profiles.
(US$29)It appears they also have a version of the FM-2028 handle
(US$9-10), though it is wired for the genuine Hakko FX-951 soldering station.
You may also want to check out the
KSGER Store; they have a nice selection of their own version of the OLED T12 controller, including one with the correct 9051 handle and the new V2.01 controller like BG has above that includes battery backup, multiple iron profiles and a larger 1.3" OLED display for only US$26 right now.
(US$20-46) If I were shopping for a T12 Controller right now, this is the version I'd get.
Cheers, and good building!
T12-birds are GO!
