None of that negates the fact that my procedure does, in fact, neutralize the electrolyte’s attack on the device in question, and that it does so better than water and a toothbrush alone.
I don’t care WHY or HOW it works. I only care THAT it works, and that I have the materials on hand to NEUTRALIZE the damage.
Empirical evidence is valid too; there’s a lot more than just alkali in alkaline battery chemistry, just as there’s a lot more than just ammonia and water in Windex.
That’s not a straw man; that's just using what works. Maybe you should try it; maybe you can tell me why.
It's a strawman argument because you're arguing against something I didn't say but something you've set up and then knocked down.
Did I say that it didn't work [to get the whole thing clean] - no. Yet you are insisting that is the argument. That is the classic strawman.
If you use the words 'neutralize' and 'alkali' in the same sentence any reasonable observer is going to conclude that you're using the particular meaning of 'neutralize' that pertains to alkalis. (Go on, google "neutralize alkali" and see what you get.) Same as if you're using 'walk' and 'dog' in the same sentence. If you're going to retrospectively claim that "I'm going to walk the dog" used the meaning of walk that is "move an object by rocking one edge from corner to corner repeatedly" then you're going to get shot down in flames. The same applies if you're going to implicitly retrospectively claim that you used 'neutralize' in some other sense than the one pertaining to alkalis and then go huffing and puffing "I know better because it works" when someone points out that alkalis don't neutralize alkalis, only acids do, then you're gonna look childishly intransigent.
No, I'm just tired of picking this particular nit with you, old friend. This isn't the first time, it probably won't be the last.
I said MIGHT. I never said you DID make those arguments. Yet somehow, I DID know you'd come along and bust my balls, nonetheless...
I've deferred to your superior knowledge of chemistry many times before, I don't deny it now. But THIS PROCESS WORKS. I've tried it, and compared it to the same process with plain water just to make sure it wasn't all in my head. While there are LOTS of thing that ARE just in my head (trust me you don't wanna look too deep in there; it's full of scary things and it smells funny
); this is one thing which I've proven to my own satisfaction WORKS.
And at this point in my life, that's all I need to know.
Windex is also good for making children squawk.
