Here you go bd.... I think I may have found a keyboard we can't beat to death.
This ReDragon K556 has been on my RADAR for a while; I like the compact footprint, minimalist design and and was interested in the promise of an aluminum chassis. Did they ever deliver on that! Bottom frame is aluminum extrusion; top is 1.55mm brushed-finish black anodized plate. Even the end-caps are aluminum.
I'd been thinking aboot this one or the white-backlit Durgod K310 for a while; when I got lucky and Windoze activated with the Key off the side of the boi's old PC, I decided it was okay to actually shop a new KB for me and kick my old one down to him. The clincher was yesterday morning when the K556 showed up in my Wish List with a $20 off Prime Member discount; that made it ~US$66 delivered.
According to reviews, switches are Outemu browns; they are nice & quiet with a medium detent at approx 2mm/50% deflection. The metal chassis makes the dull thunk as the keys bottom out quite satisfying to these brutish old dwagon paws.
As you can see, they included an assortment of other keys for you to experiment with. In this application, I think I'll stick with the original switches; maybe shop a set of Romer-Gs or even genuine Cherry browns if they don't hold up.
The only thing I see that bothers me even a little is the fact they used SMD RGB LEDs on the mainboard instead of the usual 3mm LED inside the keycap; as brightness and clarity are more than adequate, I only mind this in principle, and will choose to see it as one less probable point of failure.
*clicky-clicky-clickety-clickety*
