Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14946560 times)
nfmax, wkb and 260 Guests are viewing this topic.
Online wkb
« Reply #90950 on: May 16, 2021, 09:02:35 am »
What I need right now is an exterminator, we have some varmint hiding under the roof.
My daughter's dog would love that. The only thing that distracts him from chasing a ball is a squirrel or something under the floorboards.
Hubby said that getting rid of it using H2S or HCN was not an option ...
You might like to choose a method which enables you to remove the corpse.
Flamethrower?
browsing thru styropyro's concoctions ...
"I love the smell of burning styrene in the morning.."
« Reply #90951 on: May 16, 2021, 09:03:16 am »
Sorry for my missing enthusiasm, but from an RF perspecitve this repair is absolutely substandard.
Why not wait for a proper replacement mixer so signal integrity is preserved ?
 >:D |O :--
If it works & meets specs, the only objection can be aesthetics.
When I worked in TV & Radio Broadcasting, we often had to subsitute equivalent, if "different looking" components to maintain service, especially with equipment from Europe.
Many of the EU manufacturers had an "Australia? -----------Too far away, let 'em wait!" attitude!
On one occasion, a 10 kw Thomson TV transmitter had its 28v high current DC supply fail.
Repair or replacement?
Repair was measured in weeks (if we could get the parts), replacement in months, which was not good enough for the owners of the Tx, who were a country commercial station, with no backup transmitter.
As luck would have it, we had a spare 32v Power supply from an NEC transmitter, belonging to the National broadcaster, who agreed to a loan.
It could be shifted down in voltage, & still had sufficient current capacity.
The problem was, it was much bigger than the failed one, so it sat outside the Thomson, with big, thick cables making the requisite DC connection.
The NEC was fully enclosed, so was safe by the standards of the day, but these days, people would scream Aieee!  & run around in circles! :scared:
The NEC supply did sterling service for months, till the replacement Thomson unit arrived.
I have to be with Wolfgang on this one. The original "A" style case mixer had its case soldered to the PCB around the edges. They didn't do that for fun. I'd posit that it was to reduce leakage or radiation from th case. The B case replacement has leads up in the air, clearly not the same. It is debatable if this makes any difference to the performance but I/m pretty sure the unit was not fully tested to specification for spurious outputs and noise, including phse noise, across the whole output range of frequency and amplitude. It probably does not matter for most applications, but why not do it properly?
Offline Saskia
« Reply #90952 on: May 16, 2021, 09:11:48 am »
Flamethrower?
Thinking about it, a snake might be a good solution. Maybe bean could send me a brown snake ...
Online beanflying
« Reply #90953 on: May 16, 2021, 09:15:43 am »
Flamethrower?
Opt for a Python all the pest removal skills and generally none of the Venom or really really bad attitude  ;)
Mmm might be time to add one here from Queensland video mid way down the page eating a Possum  :-DD https://www.australiangeographic.com.au/blogs/creatura-blog/2018/08/scrub-python/
« Last Edit: May 16, 2021, 09:23:56 am by beanflying »
Offline capt bullshot
« Reply #90954 on: May 16, 2021, 09:21:34 am »
... It probably does not matter for most applications, but why not do it properly?
Simple answer: Because the unit was on my bench for one day only, and this success is worth more than waiting a few days or weeks for the proper mixer to be ordered and delivered.
The following users thanked this post: mnementh, DC1MC, tonyalbus
Offline Saskia
Online ch_scr
« Reply #90956 on: May 16, 2021, 09:29:10 am »
Kikusui in Dresden for local pickup ...
https://www.ebay-kleinanzeigen.de/s-anzeige/sehr-seltenes-2-kanal-hybrid-oszilloskop-kikusui-dss5040-40mhz/1765824421-168-3841
Ahh yes, the "pee-yellow" color scheme really is very seldom seen.
Edit: upon closer inspection, it does have digital storage and roll mode so it's quite a bit more than the basic analog 2-ch jobby.
« Last Edit: May 16, 2021, 09:30:58 am by ch_scr »
« Reply #90957 on: May 16, 2021, 09:48:21 am »
I've said it before. Everything in Oz that crawls will kill you.  :scared: :scared:
Offline DC1MC
« Reply #90958 on: May 16, 2021, 11:01:39 am »
For the (German) Nixie lovers a pair of affordable beauties:
https://www.ebay.de/itm/254972944881
https://www.ebay.de/itm/254972939553
Cheers,
DC1MC
Also, what are these   :-//, Tek delay lines, worth having for the cable:
https://www.ebay.de/itm/384149027496
« Last Edit: May 16, 2021, 11:07:55 am by DC1MC »
« Reply #90959 on: May 16, 2021, 11:21:48 am »
This is one of the AD587UQ references (thanks to BU508):
Note, the jumper is disconnected, it's the factory trimmed output.
Lucky one, but TC near room temperature looks slightly worse than the AD587KN that I've murdered. Don't have any quantitative measurements, need to set up this sometime. It's quite a long time ago that I've looked into logging data from the 34401A through GPIB.
The following users thanked this post: BU508A, med6753, 1Ghz, mnementh, ch_scr, DC1MC
Offline factory
« Reply #90960 on: May 16, 2021, 12:42:38 pm »
For the (German) [snip] lovers a pair of affordable beauties:
Cheers,
DC1MC
Interesting the DVM is part hollow state, one of my 1960's Solartron DVM is too.
What are the new ePay rules the seller doesn't like, have they got to have the ePay managed crap too?
The Tek delay lines probably belong with one of the piles of scope boards they have listed, not sure exactly which models they are from.
« Last Edit: May 16, 2021, 12:45:18 pm by factory »
Offline McBryce
« Reply #90961 on: May 16, 2021, 01:11:16 pm »
Looks like you need to calibrate something. If they both show 10.00014, but one is connected via a second lead that must have a voltage drop, then one of them is either reading slightly low or the other slightly high. :D
McBryce.
« Reply #90962 on: May 16, 2021, 01:27:17 pm »
   https://xkcd.com/814/
because that's where I stopped reading.
« Reply #90963 on: May 16, 2021, 01:31:02 pm »
McBryce.
Assuming the test leads have 1 Ohm resistance (they don't, it's rather 0.1Ohm ballpark), voltage drop across them would be 1uV (assuming the 34401A is set 10M input impedance) - the last digit shows 10uV resolution   ::)
Anyway, both multimeters are specified to about 40ppm at this range and readings, that would be +/- 40 digits here ...
« Last Edit: May 16, 2021, 01:36:07 pm by capt bullshot »
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #90964 on: May 16, 2021, 01:35:52 pm »
... voltage drop across them would be 1uV ...
And you're ok with that?
Online tggzzz
« Reply #90965 on: May 16, 2021, 02:05:50 pm »
If not, then put the meters in high impedance mode :)
« Reply #90966 on: May 16, 2021, 02:19:49 pm »
« Reply #90967 on: May 16, 2021, 02:21:30 pm »
@med: "Hi.... welcome to TEAnonymous! Have we met...?" :-DD
Putting a working firearm in the hands of anybody but me terrifies me.
Most of the world is very different to the US where in most countries sidearms are very redistricted whereas a longarm should be considered as just another tool and firearms have perfectly valid uses and gun sports are part of Olympic competitions where those competitors are just as heavily invested as us here in TEA.
We each have different hobbies and interests.
I had to make a mini-glaive yesterday by zip-tying a paring knife to a pole; the ding-dong who installed our dryer vent left the zip-tie on it from when it was on the shelf in the store, and I couldn't get the grill off to clean it. :palm:
*puts on best rainman voice*   "a tool... definitely... definitely a tool... definitely.... definitely..."
« Last Edit: May 16, 2021, 02:24:18 pm by mnementh »
Offline vk6zgo
« Reply #90968 on: May 16, 2021, 03:26:06 pm »
The local hardware store stocked "Live animal traps".
My thought was that they wouldn't work at all well for dead ones!
Zombie varmints??
Offline kj7e
  • Damon Stewart
« Reply #90969 on: May 16, 2021, 03:36:01 pm »
Just going to leave this right here;
« Last Edit: May 16, 2021, 03:39:57 pm by kj7e »
Offline Ice-Tea
« Reply #90970 on: May 16, 2021, 03:57:34 pm »
Considering trying out Bonanza as a kind of civil disobedience towards eBay. Experiences?
« Reply #90971 on: May 16, 2021, 03:59:40 pm »
Flamethrower?
Nah, it would be just as bad smelling the cooked varmint as it would be the rotting varmint for the next few months  :-DD
« Last Edit: May 16, 2021, 04:09:51 pm by Specmaster »
Offline Ice-Tea
« Reply #90973 on: May 16, 2021, 04:48:36 pm »
You BASTARD!!! Made me snort coffee out my nose...
Now I gotta go wash my keyboard... aww jeez, in my mouse too...?  :palm:
« Reply #90974 on: May 16, 2021, 05:00:22 pm »
Well, I'm disappointed in all of you splitting hares over the whole thing if you're not going to take the RThévenin of the source into account which, calculating from the datasheet's output regulation figures, might be as high as \$100m\Omega\$, on the same order as the resistance posited for the test leads (Which by the way, from previously having measured my collection of test leads, is likely to be close to \$20m\Omega\$).  :)
The following users thanked this post: capt bullshot
