Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14971116 times)
Vince, URI, shakalnokturn and 137 Guests are viewing this topic.
« Reply #10650 on: May 15, 2018, 04:52:12 am »
...I got rid of my adult supervision quite a while ago, so I have no one to protect me now...
Aha!  Now I understand how such a purchase is possible.
Yay for lack of adult supervision!!
Hmmm...  On second though, perhaps some adult supervision might be a good idea...
Nahhh, screw it. That ship has sailed.  Off to the bay of evil!!
-Pat
They're congregating...or perhaps colluding. Did you recently schlepp some of the units I see there?
« Reply #10651 on: May 15, 2018, 04:54:28 am »
I snagged that a few years ago out in CA; the display was not working so I gambled for $350 IIRC (plus another c-note to ship it home; the friggin thing weighs around 75 pounds!).  It turned out to have two bad electrolytic caps in the display driver circuitry; it was all of about $3 in parts to bring it back to life.  I lucked out on that one!
 :o Talk about scoring a deal! Now, that's a TEA party.
« Reply #10652 on: May 15, 2018, 05:11:09 am »
OK gang, put the kiddies to bed. Tell your XYL it's normal to look. Dim the lights. Tek 2465 pron to follow...
Pix1: The top plate with original factory sign-offs. I did not pull the top plate.
Added to POI index. :-+
Offline tggzzz
« Reply #10653 on: May 15, 2018, 07:46:54 am »
Excellent collective noun: "a collusion of test equipment"
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #10654 on: May 15, 2018, 07:55:49 am »
-Pat
Indeed I did.  You obviously recognize the pile just to the left of center as my recent score.
-Pat
Offline Cubdriver
  • Nixie addict
« Reply #10656 on: May 15, 2018, 08:20:58 am »
Yes, it certainly was.  They were asking $500 IIRC, but when we plugged it in and it showed no signs of life other than the fan spooling up, I offered $350 and they accepted.  I'd recently read about the VFDs in them going bad, and seen something about fitting fourteen segment LED displays - likely here - and figured that was always a possibility.  It seemed a bit odd that BOTH displays had failed, though, and thought I'd seen a tiny flicker in one of them, which meant power supply issues were a possibility, too.
I found schematics and started poking about, and the trouble revealed itself quickly when I looked at the board with an IR camera and saw two glowing electrolytics.  I did some probing with the scope to make sure the drive was there, then replaced them and lo and behold, the display lit right up!  Sweet!  I ran the self cal (Lord only knows how long it was on a shelf before going to surplus), then checked it with the recently calibrated bench meter at work, and it read pretty much dead on.  I was a happy camper til time to figure out packing it came along - that was a challenge.  It's about 24" long, so I had to modify one of the 24x24x24" boxes I normally ship my boat anchors home in to make it longer and thinner.  PITA, but it made its cross country trek unharmed, so all is good.
It's funny when packing the instrument to ship it winds up being more challenging than bringing it back to life was...
Edit to add repair images
The display board (display power supply circuitry at bottom right):
The overheated cap (seeing the pic reminds me that just one was bad.  I shot gunned them, though.  The thermal and visible outline images are misaligned because the picture was taken with the thermal camera quite close to the board and there is parallax error between the thermal and visible light lenses. The thermal image is above the visible light image):
-Pat
« Last Edit: May 15, 2018, 08:41:07 am by Cubdriver »
« Reply #10658 on: May 15, 2018, 08:37:00 am »
I'm busy convincing myself now :D
« Reply #10659 on: May 15, 2018, 08:40:47 am »
Actually I've unconvinced myself now as I have a couple of other things on the watch list which are more important at the moment.
Offline Mr. Scram
  • Display aficionado
« Reply #10660 on: May 15, 2018, 08:43:09 am »
I wouldn't quite know what to use one for. I can't come up with anything I can't already do.
Offline Cubdriver
  • Nixie addict
« Reply #10661 on: May 15, 2018, 08:44:02 am »
You're weak, bd!!   :-DD
(Only with this lot could RESISTING the temptation to buy something you really don't need be considered a weakness.  :o )
-Pat
« Reply #10662 on: May 15, 2018, 08:48:16 am »
Keeps the TF930 company on the shelf.  :-DD
« Reply #10663 on: May 15, 2018, 08:49:38 am »
It does have the “matching cushions appeal” :)
Believe me the other things I have my eye on have a considerably higher “woot factor”.
Plus lame as it is, the old 555 makes a pretty good pulse gen  :)
« Reply #10664 on: May 15, 2018, 08:51:44 am »
At that price they wont hang around for long, the only other ones currently in the UK offered for sale 2nd hand are going for £195 and £395 respectively.
« Reply #10665 on: May 15, 2018, 08:58:46 am »
Well I can be smug about it cos I've got that matching cushion effect cos I got mine from the last lot that they had. Then again like you I also have the means of doing other ways and I had considered selling it TBH but not while they have them on offer, its pointless  :-DD It could be a good investment though if I hang on to it for a while  :-+
Offline Mr. Scram
« Reply #10666 on: May 15, 2018, 09:00:37 am »
It would be the odd one out, as it would be one of the few items that can't be hooked up to a computer.
Offline tautech
« Reply #10667 on: May 15, 2018, 09:04:35 am »
Nah, you have just enough voltage from USB to make them work.  :phew:
Avid Rabid Hobbyist
Offline Mr. Scram
« Reply #10668 on: May 15, 2018, 09:10:13 am »
What?
Offline tautech
« Reply #10669 on: May 15, 2018, 09:11:02 am »
What?
555
Avid Rabid Hobbyist
Offline Mr. Scram
« Reply #10670 on: May 15, 2018, 09:12:52 am »
555
Ah, I was referring to the TTi units. Hooking up a 555 to USB power would technically be hooking it up to a computer, but not quite what I meant.  ;D
« Reply #10671 on: May 15, 2018, 09:28:01 am »
555
I'm not at all sure that I'm understanding you with this one, the TF930 has a USB port but that is just another option for providing portable power, the TGP110 is purely 240v driven and neither of them has a GPIB connector, so in what way was you thinking of computer linking them?
« Last Edit: May 15, 2018, 09:38:36 am by Specmaster »
Offline tggzzz
« Reply #10672 on: May 15, 2018, 09:48:54 am »
Heads everyone, TTi TGP110's are back in stock again and they have 18 in cream and 19 in grey.
I'm not really sure why I would want a pulse generator; any of the pulses I would want would be more conveniently generated by a pattern generator.
Having said that, I recently picked a Tek 115 up for £5, and that does one thing a pattern generator won't: have (independently) variable rise and fall times. Mind you, neither does that TTI.
The Tek 115 is remarkably versatile, being able to generate double pulse and, with an external signal triggered bursts. The TTI doesn't look like it does that either.
Example, with equal rise/fall times:
Ob porn: the front panel showing rise and fall time controls, and one interior shot showing old-school wiring looks and, if you look closely on the left, 863pF, 908pF and 9.85nF capacitors.
EDIT: much more detailed porn of this instrument here: https://www.flickr.com/photos/anachrocomputer/albums/72157690644170820
« Last Edit: May 16, 2018, 07:52:40 am by tggzzz »
Offline Mr. Scram
« Reply #10673 on: May 15, 2018, 09:57:40 am »
The USB port is not just for power.  :) The TF930 is SCPI enabled, even though it uses a shorthand dialect. You can control all its functions through a PC.
« Reply #10674 on: May 15, 2018, 10:04:21 am »
That's a thing of beauty!  :-+
Another xfce user I see as well :D
