Here's a TEA question. Have any of you had a piece of test equipment stop working, so you think "If I had a manual maybe it would have some servicing information and I could fix this thing." So you get on the computer and fire up your favorite search engine, and after some searching consider yourself lucky to have found a PDF of the manual online. So you save the PDF and look at it a bit and figure that's good enough for today. Later I'll dig into it and fix the piece of test equipment.
The next day you go back to the lab and see that you had a manual all along. A real physical copy, sitting on the shelf a few feet from the piece of test equipment, and only a couple feet from where you were sitting while searching for the manual online...
Well, I'm a bit ashamed, but as we are all TEAs here I'll disclose one of my secrets..
This happened to me.
Yes.
But a little bit different
Once I got a manual with a TED (Test Equipment Device), put it aside on my bench and played with the new toy.
A stack of other paper grew on it.
I eventually forgot about it.
Then, one day, I wanted to use the instrument and had some issues with it, so I needed a manual.
I searched on the net (it was quiet rare) for a paper copy because of the schematics and felt lucky to find an original (no copy) I could buy from a guy in Germany.
The manual arrived, I fixed the issues and put it on the shelf aside my other paper manuals.
Month later.. I rebuilt my bench and before that I had to tidy it up.
To my surprise at the bottom of a paper stack there was a manual that I clearly remembered I had put on the shelf month before, how could it get here on my bench again...?
