Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14950086 times)
RFMWdude and 228 Guests are viewing this topic.
« Reply #22700 on: January 14, 2019, 07:54:20 am »
A quick sneak peek/ preview. About 3/4's unpacked now.
One of the coolest things about the seller was he gave me this pen and said his grandfather would be happy knowing the lot is going to get some good use. I told him I was honored and will make him proud! The 'Cal stickers' are from his former lab out in California; maybe someone here knew him?
That's an impressive haul[emoji106]
« Reply #22701 on: January 14, 2019, 08:02:51 am »
How about another DMM?
Already have one but the Advantest is over width and height for the space available. With a reshuffle I can now fit in a 3458A by dropping the Racal for the rear and drop the 34401A on top of the Siglent. Advanced Planning/Tetris at work  ;D
Offline Inverted18650
    • Test Gear Addicts
« Reply #22702 on: January 14, 2019, 08:17:29 am »
Not a bad start! I do not see sleep coming easy tonight, but this is SO MUCH FUN! :-DMM
beanflying: PICK SOMETHING!  :popcorn: What dimensions are we looking at? How much room do we have to play with?
« Last Edit: January 14, 2019, 08:19:30 am by Inverted18650 »
« Reply #22703 on: January 14, 2019, 08:23:05 am »
Nope Struck out there I have a Valhalla 2703 AC Calibrator in very nice order and several DMM's better specced than the HP  ;)
    • Test Gear Addicts
« Reply #22704 on: January 14, 2019, 08:42:40 am »
Hidden treasures..
Offline tautech
« Reply #22705 on: January 14, 2019, 09:00:37 am »
Hidden treasures..
What's gunna be for sale ?  :popcorn:
Avid Rabid Hobbyist
« Reply #22706 on: January 14, 2019, 09:14:40 am »
Holy crap there's a lot of cool stuff there.
Wonder if the power sensors work  :-DD
    • Test Gear Addicts
« Reply #22707 on: January 14, 2019, 09:37:18 am »
Unfortunately, I HAVE to sell most of it to cover costs...but that'll be done in another thread. Here I just want to play and share with everyone, but you're welcome to PM me if something catches your eye.
Cheers,
Chris
Online med6753
« Reply #22708 on: January 14, 2019, 09:38:51 am »
It's too bad you are not closer to me. I would love to borrow that 5200A just once. Of all the references I have here AC function is almost totally lacking. I have 1 reference, 1VAC/60Hz. And it's not all that accurate. According to consensus with my DMM tribe it measures 1.005VAC to 1.008VAC.
Coldest day of the Winter so far. -12 C outside. Brrrr.  :o
Online med6753
« Reply #22709 on: January 14, 2019, 09:40:23 am »
Cheers,
Chris
Well, when you get a total inventory post it up.  :-+
    • Test Gear Addicts
« Reply #22710 on: January 14, 2019, 09:46:35 am »
Maybe we can work it out, I do NOT plan to sell the 5200 unless I am in a pinch, and even then, Id go do a real job for a little to get to money to keep it. As such, once I get it up and running, and warm for a few days, I'll record and send you the data, then if you do end up using it, you can cross-reference...Its not out of the realm of possibility.
Online med6753
« Reply #22711 on: January 14, 2019, 09:55:26 am »
Sounds good!  :-+ :-+ Taken 5 minutes ago. This is how my new Siglent resolves the 1VAC reference.
« Reply #22712 on: January 14, 2019, 09:58:39 am »
You're turning into a voltnut  :-DD
(nothing wrong with that. I'm turning into a time nut)
Online med6753
« Reply #22713 on: January 14, 2019, 10:04:51 am »
Guilty as charged.  :-DD I've never been able to properly calibrate the AC function on the Tek 2465 DMM because it requires constants of 190mVAC, 1.9VAC, 19VAC, 190VAC, etc and NOT just at 60Hz. And I know it's way out of spec because it's about 3VAC high when measuring line voltage.
    • Test Gear Addicts
« Reply #22714 on: January 14, 2019, 10:06:07 am »
If you would like to test them, I'll mail them to you...I feel like you are *another one of the forum pros who make this site as valuable as it is today. (just say, "they don't work" and keep them)  :-/O  This way if I put, "non working, scrap on the box, for all I know, its the truth.
« Last Edit: January 14, 2019, 10:08:36 am by Inverted18650 »
Offline Brumby
« Reply #22715 on: January 14, 2019, 10:11:41 am »
« Reply #22716 on: January 14, 2019, 10:17:12 am »
My AC Calibrator is one of the more indulgent bits of test gear I own and has been used maybe a dozen times since I got it but there really isn't any other way to properly test true RMS meters. Pony up @Med you know you 'need' too  :-DD
The table has lots of cool stuff on it too.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #22717 on: January 14, 2019, 10:24:14 am »
Damn, Inverted - that's quite a haul!
I finally ordered a manual for the non-working Fluke 5200A I got a few months ago.  It will be nice (assuming I can repair it) to have AC capabilities.  If/when I do, med, I think you're only about two hours away from me - certainly within schlepping distance for a potential play date.
-Pat
Online med6753
« Reply #22718 on: January 14, 2019, 10:28:52 am »
Yea, I may have to pony up. I did throw together a crude AC calibrator once by using a function generator, a power transformer connected in reverse, a voltage divider with a pot. It got me pretty close on the lower voltages at 60Hz but when one of cal points was 19KHz the power transformer said "FU"  |O. And no way could I get 190VAC RMS.
Online med6753
« Reply #22719 on: January 14, 2019, 10:30:26 am »
-Pat
Let me know and I'll be on the road.  :-DD :-+
Offline tautech
« Reply #22720 on: January 14, 2019, 10:36:08 am »
-Pat
Yep, you got some time now for road trips.....and play dates.  :)  :-+
(Jealous)  :scared:
Avid Rabid Hobbyist
Online med6753
« Reply #22721 on: January 14, 2019, 10:38:02 am »
-Pat
(Jealous)  :scared:
Damn straight skippy. I got all the time in the world now and I'm fucking loving it.  :-+ :-+ :-DD
« Reply #22722 on: January 14, 2019, 10:38:42 am »
Inverted18650's house is going to look like this for a bit  :-DD
(from Resident Evil)
Offline tautech
« Reply #22723 on: January 14, 2019, 10:57:21 am »
-Pat
(Jealous)  :scared:
What's this skippy bit ? I'm K1w1 !
Them our ex convict cuzins.  :-DD
Avid Rabid Hobbyist
Offline tautech
« Reply #22724 on: January 14, 2019, 10:58:33 am »
Already placed my order before the fence went up.  :phew:
Avid Rabid Hobbyist
