Yeah can’t moan for £3 at all. An afternoon of debugging fun is a pretty cheap exercise. I’d be annoyed if I’d spent £10 on it.
I looked on the Caddock site just out of dumb curiosity; it appears they've stepped into the 21st century and don't even acknowledge the existence of products in DIP package.
Would be an interesting exercise to see if you can re-create the network (and how close to "right" you can get) using precision SMT resistors though.
That is definitely possible but it is entering the "i can't be arsed" territory
Yep, my first decent scope had one of those on it but it is still no match for dedicated testers, for instance, it will test a resistor and will present you with a straight line at an angle and the angle will determine the resistance value, but you cannot read that value, but a DMM does that perfectly, yes it will also test a capacitor, but so will many DMMs or dedicated LCR meters etc and will also give a value for them, so do I miss not having a component tester on my current scopes, not in the slightest bit
I think both are important. In the case mentioned above it told me when a transistor turned into a resistor because I abused it
Anyway onto item two which is a lot better. Got the heathkit VTVM up. Cleaned it up a bit and cracked it open and there was a mildly crusty battery in it. It didn't destroy the battery holder for once which was good. Insides are not particularly well constructed. 1959 dated electrolytic and stripey selenium rectifier of doom have been evicted and replaced with a cap / diode / resistor combination to bring the HT total to 150V. Turned out 1.2K and 1N4007 was about right after some experimentation on the breadboard. New cap was radial - that's all I had. I did use PCB pins though
. Gave the switches a quick spray and it zeroed straight away and takes a DC reading almost on the mark. Was slightly surprised there.
To do: new mains lead and earth it, internal 1M resistor (sod the nice probe kit for this one!), replace the large waxy cap in it (on order RS 10x for £0.20 inc delivery!), apply some turd polish.
Inside:
Outside:
So total expenditure on that is £12.20. Pretty good.
