Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14946303 times)
morris6, wkb and 268 Guests are viewing this topic.
« Reply #88375 on: April 17, 2021, 05:21:32 am »
Scored this today, lucky my cousin spotted it for me, all for AU$90.
Good deal.
Wolfy, what's the LH plugin ?  :-//
Avid Rabid Hobbyist
Online beanflying
« Reply #88376 on: April 17, 2021, 06:52:41 am »
Nice CrusTEA  :-+ did you BWD also?
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #88377 on: April 17, 2021, 06:57:24 am »
Good deal.
It appears to be part of the 7L13 itself.
https://w140.com/tekwiki/wiki/7L13
-Pat
The following users thanked this post: wolfy007
Offline wolfy007
« Reply #88378 on: April 17, 2021, 07:00:12 am »
Good deal.
-Pat
Yup its part of the 7L13, the 7L12 is double width (as is the 7L5), the other SA plugins are three wide.
PS: Also supports a tracking generator via the LO outputs on that extended bit.
« Last Edit: April 17, 2021, 07:04:59 am by wolfy007 »
Offline wolfy007
« Reply #88379 on: April 17, 2021, 07:01:54 am »
Nope, didnt think it was worth AU$140.
Online beanflying
« Reply #88380 on: April 17, 2021, 07:04:17 am »
Weak  :-DD There is another 50Meg turned up BIN in Vic today too.
« Reply #88381 on: April 17, 2021, 07:27:08 am »
Recently on ebay:
10x 0.1R      0.1%   Burster Type 1168
10x 1R        0.1%   Burster Type 1168
10x 10R       0.05%  Burster Type 1166
10x 100R      0.02%  Burster Type 1164
10x 1000R     0.02%  Burster Type 1164
10x 10000R    0.02%  Burster Type 1164
10x 100000R   0.02%  Burster Type 1164
Today arrival:
Have not decided yet, if I'll built a resistor decade box or if I'll make some resistor calibration sets.
What do you think?
Cal boxes. Also pick the best MATCHED three and arrange the binding posts so you can use as a Hamon divider.
« Last Edit: April 17, 2021, 07:35:48 am by Robert763 »
Offline wolfy007
« Reply #88382 on: April 17, 2021, 07:28:16 am »
Yup saw that one, what I would really like is one of the BWD Mini-Labs tho. :P
Online beanflying
« Reply #88383 on: April 17, 2021, 08:01:57 am »
Mini Lab would be a cool thing but anyone selling them thinks they are a gold centered Unicorn Poo.
Shame this beast is on the wrong coast and it has been "digitized"  :palm: https://www.gumtree.com.au/s-ad/leeming/other-electronics-computers/bench-power-supply-bwd-model-242a/1272456970 $2-300 in freight at a guess.....
The following users thanked this post: wolfy007, factory
« Reply #88384 on: April 17, 2021, 08:28:44 am »
Ooh 7L13. Nice. I had that 7L12. Much fun excavating that to find a duff tant  :-DD
Offline Brumby
« Reply #88385 on: April 17, 2021, 08:45:59 am »
Nice CrusTEA
+1  :-+
Offline Bad_Driver
« Reply #88386 on: April 17, 2021, 09:14:28 am »
Power Supply time this weekend
I have seen people trying the 6006. so i ordered the 6018 , 1080Watts  8)
And a new 'Sleep-over' borrow from ELEshop.nl / Eleshop.eu
I got a Riden RD6018 some weeks ago and it is impressive with respect to the price.
Since I‘m sometimes work with power amps I think about a second. I will wait
until they can again deliver all three parts from a european warehouse to avoid the risk
of customs.
There  are rumors that they will come with a dual source PSU.
Online beanflying
« Reply #88387 on: April 17, 2021, 09:26:09 am »
Five overpriced BWD Mini Labs in the UK - platinum filled Unicorn Poo  :palm: eBay auction: #265105982971
« Reply #88388 on: April 17, 2021, 10:23:59 am »
OK so that's what the infamous minilab really looks like as only seen B&W images of them.
If anyone wants a BWD Wavemaker 170 I'll let it go for $50 NZ + postage.
Avid Rabid Hobbyist
« Reply #88389 on: April 17, 2021, 10:31:47 am »
Good deal.
-Pat
Ta Pat, and so it is:
Link to pic:
https://w140.com/tekwiki/wiki/7L13#/media/File:Tek_7L13_B110xxx_front.jpg
Wolfy might have fun finding the original knob.  :scared:
Avid Rabid Hobbyist
« Reply #88390 on: April 17, 2021, 10:44:44 am »
Little puzzle for you amp nuts
Shed stereo Sony STR-DE-485 after a couple hours starts randomly rattling relays yet with no ill effect on the output.  :-//
Now it's autumn occasionally it goes into Protect mode however after some 20 mins ON and after a power cycle works perfectly fine...until next time. As the thing is top vented I guess there will be a good layer of crud and dust on the PCB so I reckon just some TLC will sort the Protect mode but whaddabout the rattling relay ?
Avid Rabid Hobbyist
Offline capt bullshot
« Reply #88391 on: April 17, 2021, 10:49:27 am »
Check supply voltages for ripple. I've seen one diode of full bridge rectifiers failing intermittently, resulting in 50(60)Hz ripple instead of 100(120)Hz ripple. Sometimes the circuit still works then, but if it heats up it starts to fail randomly.
« Reply #88392 on: April 17, 2021, 10:55:57 am »
Yes PSU ripple had crossed my mind however the main amp PSU seems to be working fine as it's still driving the 5 speakers without hum or noticeable distortion and able to blast us out of a 4 car garage when Pink Floyd get played and you crank it right up !  :-DD
Avid Rabid Hobbyist
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #88393 on: April 17, 2021, 11:00:15 am »
Five overpriced BWD Mini Labs in the UK...
That's what they call "mini"?
 :-DD
« Reply #88394 on: April 17, 2021, 11:00:53 am »
So check how the lower voltage auxiliary supplies are generated. Might be a separate winding (with failed bridge rectifier) or some nasty dropper resistors from main amp voltage causing local hot spots on the PCB and nearby components failing ...
« Reply #88395 on: April 17, 2021, 11:04:34 am »
Yep all simple stuff you would normally spot with a little experience....spose I should go looking for a SM....oh hang on I've already got one on my Manual folder !  :-DD
Avid Rabid Hobbyist
« Reply #88396 on: April 17, 2021, 11:08:07 am »
If it's a single sided board, check for broken solder joints. Mechanical or thermal stress makes them unreliable.
« Reply #88397 on: April 17, 2021, 11:12:38 am »
Remember that's the exact same unit I worked on for my brother almost 2 years ago which also had an intermittent protect mode. Never did track down the exact cause. I pulled the main board out and resoldered the output transistors plus any suspicious looking joints, especially in the PSU area. Ran it for several days with no fails. Returned it to my brother and last I heard it was working fine.
The following users thanked this post: tautech, mnementh
« Reply #88398 on: April 17, 2021, 11:13:09 am »
Yeah they generally are SS with lots of bare jumper wires however I'd rather not pull the PCB unless I need to.
It's one of them rainy day jobs when there's not much else on which is hardly ever !
Avid Rabid Hobbyist
« Reply #88399 on: April 17, 2021, 11:18:12 am »
No I didn't but a jog of the memory cells rings a bell. Thanks.
But strange that the random rattling relay has no ill effect on sound or the display...zip, nuthing, nada !
Avid Rabid Hobbyist
