From the ALL THE LITTLE FIDDLY-BITS Dept...So... the last few days, I've been pressing the boundaries of WAF and Type 2 JENGA; the FatBike has been up on tables in the LR (poor wife & kids on the far end of the couch to be able to watch TV around the damned thing, me cussing whenever I dusted a knuckle or burned myself grinding/soldering/friction-ed against something that was turning... we all know the drill
) for all the "little fiddly-bits" tinkering needed to make a
"Fitzall eBike Motor Kit" actually fit. I bought this kit after the 26" wheel & hub motor kit turned out to be wholly unsuitable; the weight of that thing is just ridiculous for a bike one intends to actually pedal most of the time. My interest is just to have something that can get my fat ass home if my bum knee decides it has had enough for the day and locks up on me.
Fortunately the project is mostly done now and the beast back on the floor; a little
Widlarizing blunt-force metal bracket rehabilitation here, a new 10mm thick 3DP sprocket spacer there, add a fistful of washers and we're at the point of actually starting to put things together.
-group-therapy-thread/?action=dlattach;attach=1226194;image)
First up, I had to completely dismantle the gearbox on this motor unit; as it came the power wires exited the motor in exactly the wrong direction, and of course, I
needed the ~180mm difference that rotating the motor assembly on the casting represented. That did give me a good excuse to peek inside & take a pic for all y'alls... actually, for CAD$130, this motor and gearbox (plus it came with speed controller and throttle assembly) is quite a lot of precision manufacturing for very little money. Gear ratio is approximately 10:1 ; motor is rated ~3300RPM@36V with final output ~330RPM.
Those of you with a keen eye will notice there's something a bit funny aboot the sprocket here; it is actually a one-way sprocket meant to go on the wheel of a fixie, with a special hub to mount it to a keyed shaft. This is actually what makes this kit worth every penny; it means that you never have the pedals turning under motor power like with some kits, nor do you have the motor dragging on you when pedaling. All in a nice tidy little package that weighs ~2kg with the mounting plate.
-group-therapy-thread/?action=dlattach;attach=1226198;image)
With the motor/gearbox finally all back together, it was time to address the problem-child sprocket; the kit also comes with a sprocket, but it is one of those horrible "sandwich the spokes between plates and bits of belted rubber" things to be able to go on as many different bikes as possible. The same manufacturer also makes a gear meant to bolt to the hub under your disc brakes; as I have exactly that kind of wheels, I sprung the CAD$15 to get that too. Problem was... it is pretty cheaply made and full of burrs and a bit too thick and none of the chains I had wanted to ride properly on it.
So a little Dremel abuse followed by painstakingly hand-deburring every fucking tooth on the sprocket, and now we have a sprocket that runs gravity-feed smooth.
-group-therapy-thread/?action=dlattach;attach=1226202;image)
Once it all came together, and with several trial/error fittings to get the stack of washers on the axle right for the required brake rotor offset, sprocket alignment is pretty close. Not perfect, but good enough for a trial ride to see if this iteration is going to serve. If it works and the chain doesn't grind under load, I'll order hub adapter kits (they are available in 3mm & 5mm widths) to get machined aluminum in place of that 3DP spacer and washers. Then, I can adjust the motor angle by placing a few washers between the casting and the mounting plate.
Of course, there's always the parts you buy but you DON'T use that wind up left over... fortunately, I was able to "steal of a deal" on most of my extra bits on crazy clearance sale items from Amazon & Wally World. I found some 24V/500W speed controls being blown out on Wally World for CAD$11 each; they were supposed to come with thumb throttles but only one did. The sprocket I used was on half-price too; part of why I didn't mind having all this left over. Total extra expenditure above the $130 kit was ~CAD$35. I'm pretty sure I could blow it all out pretty quick on Kijiji, except I think I wanna revisit the scooter...
The 24V kit with thumb throttle wound up paired to the 36V-rated motor above, as my first trial is going to be with one of my 6S Kobalt Drill/Impact Driver batteries, and I need to match the ESC's LVC to the battery. I'm hoping that underdriving the motor will keep the current draw within the limits of the BMS in the pack even carting me around; I've drawn almost 20A from one of these before when powering my LiPo charger in motor test mode.
With the thumb-throttle, ESC and battery in the bag, the whole thing adds less than 5kg to the bike. I think that's a more than fair tradeoff for my intended purpose.
-group-therapy-thread/?action=dlattach;attach=1226206;image)
