-group-therapy-thread/?action=dlattach;attach=1557130)
I've got a couple of vintage TE clocks, these were made by a few TE manufacturers for adding timecode to recorder printouts & tape recording. In the case of the HP can also be used to automate the printing, with several selectable rates.
Wowwwwww.... this thing looks the business !!!
Beautiful, I want one as well now ! What do you mean it took you 20 years to find one and it's the only one you have ever seen ?!
Oh well....
Even though HP made so many millions of their TE, some of their old stuff none the less is as rare as hens teeth nowadays.
I am sure you must be very glad you stumbled upon this one !
If I pay you 20 quid, can I visit your lab for an hour and play with this thing ?!
I found the digital recorder/clock about 9 years ago, took quite some to arrive via slow parcels, from somewhere in Europe, very important it was a 50Hz version. Weight is only 83lbs (37.65kg) according to the book.
And yes I've not seen another complete recorder/clock combo since, come to think of it haven't seen any of these large digital recorders (on their own) for many years now. Have seen a couple of the clocks on their own, think one was on youtube.
You might have to wait a while before you can play with it, still need to move to somewhere I can set up a proper lab to work on my boat anchor size TE, the tiny room in my Dads workshop is not big enough.
Another problem the recorder part is completely seized up, large motor is much louder than any other TE fan here. On the plus side it uses standard size paper & typewriter ribbon.
The PSU that runs the electromechanical clock, also runs a bunch of vacuum bulbs (comparator circuits), this also runs part of the counter or voltmeter it would connect to, via changeover relay in the counter/voltmeter (need to be added too as neither counter has the extra parts fitted). It would be nice to run the clock continuously from a separate supply, with another changeover relay to allow printer use as well.
Hey, hey.. You should repurpose those things, as... Nixie clocks!
Wait a sec.........
(Needs moar blue LED
My eyes hate blue LEDs, along with cold white ones and any used with excessive brightness.
The amber plastic filter in front of the tubes would help block the light, from those pesky blue LEDs.
