Author Topic: Test equipment from Ali Baba is so much cheaper.....is it ok?  (Read 2650 times)
Offline FaringdonTopic starter
We are in for the following test kit...its often more than 4 times cheaper from Ali Baba or "China-via-ebay"
Do you know of problems with these items sourced from AliBaba
Flux
Leaded solder
HV Diff probe
Kynar wire
Kynar stripper
100:1 probe
Mains Safe block
ESD mat with htab and cord/earth plug
ESD wrist strap and plug/cord
ESD footstrap
Polyamide tape
Transformer coil tubing
7/0.2mm wire
Various Enamelled copper wire
0805 book
isolation transformer 230/230...100VA to 2200VA
« Last Edit: June 28, 2022, 10:17:11 pm by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
Re: Test equipment from Ali Baba is so much cheaper.....is it ok?
« Reply #1 on: June 28, 2022, 06:05:53 pm »
Quality is random, and if you receive something sub-par, customer service is a long way from ebay standard.
The following users thanked this post: Faringdon
Offline TomKatt
« Reply #2 on: June 28, 2022, 06:15:59 pm »
China is a crapshoot - you need to get by the product description lies before you can even begin ascertaining quality...
Thank goodness I'm just a hobbiest - because I still do not know how to identify real copper wire from all the plated crap listed as solid copper.
Even if the origin was China, if the use was commercial, I'd be sourcing from a place like Digikey etc.
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PIC
« Reply #3 on: June 28, 2022, 07:06:01 pm »
General rule is don’t buy anything that can kill you or you can’t afford to immediately throw away from China.
Polyamide tape is usually ok though.
Offline graybeard
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #4 on: June 29, 2022, 02:07:25 am »
The tape cheap enough from Amazon prime and returnable for free if it sucks.
The following users thanked this post: bd139, Faringdon
Offline Shock
« Reply #5 on: June 29, 2022, 03:14:55 am »
Flux
Leaded solder
HV Diff probe
Mains Safe block
Those I wouldn't get due to OHS, the 0805 book is ok for prototyping but not production and everything will be dependent on quality. if your goal is to sell a product you need factor in the risk of using low quality components. You get a few things returned or deal with customers on the phone troubleshooting and those cheap components become costly.
Offline f14
  • Country: vn
« Reply #6 on: June 29, 2022, 01:01:21 pm »
try aliexpress( same company with alibaba)
HV diff probe from micsig they have good price with some nice voucher
Online tooki
« Reply #7 on: June 30, 2022, 09:18:08 pm »
Flux
Leaded solder
HV Diff probe
Kynar wire
Kynar stripper
100:1 probe
Mains Safe block
ESD footstrap
Polyamide tape
7/0.2mm wire
0805 book
Polyamide (Nylon, Kevlar, etc) or polyimide (Kapton)? They’re different things.
My experience with Chinese Kapton is that the adhesive is very substantially weaker than that of name-brand Kapton tape. But it’s also a tiny fraction of the cost.
There are numerous discussions here about Chinese solder, mostly describing it as utter garbage. Why anyone would bother with that when even the most expensive solders make up a negligible part of the cost of a project or product, I don’t understand. Why risk ruining expensive parts to save some tiny fraction of a penny on solder?
Flux seems to be ok. But given how cheap name-brand flux can be, again, why bother?
« Last Edit: July 01, 2022, 07:26:40 pm by tooki »
Offline abdulbadii
« Reply #8 on: June 30, 2022, 11:39:50 pm »
kits ok 90-95%
equipment i.e. device ok 70-80%
real point is we can't easily to determine which class of imported products
China has two class export for two targets; rich/developed countries & mid/poor/undeveloped ones
so there'll be ~95% or more the same product but actually more 50% of the material quality of significantly different ones of the two
Offline DH7DN
    • DH7DN Blog
« Reply #9 on: June 30, 2022, 11:45:37 pm »
Polyamide (Nylon, Kevlar, etc) or polyamide (Kapton)? They’re different things.
This makes no sense  ;D
Kapton is a trademark of DuPont for a polyimide film.
Nylon etc. = polyamide
vy 73 de DH7DN, My Blog
Offline SiliconWizard
« Reply #10 on: June 30, 2022, 11:57:07 pm »
It's surely a typo. =)
The following users thanked this post: DH7DN, Faringdon
Online aronake
  • Country: hk
« Reply #11 on: July 01, 2022, 04:28:32 pm »
I live in Hong Kong so have quick access to taobao / alibaba. Around 4 days from order until arrive. I buy lots of things from there. Generally its good, but need to be observant and develop a skill for what is probably good or bad. And many things so cheap, so just to put an order, and if not good, just throw away.
Offline BrokenYugo
« Reply #12 on: July 01, 2022, 07:05:48 pm »
I would not buy anything safety critical and difficult to properly evaluate, e.g. isolation transformer, straight from China. That stuff should come from sources you can easily drag into court if the device ends up trying to kill you.
Online tooki
« Reply #13 on: July 01, 2022, 07:28:44 pm »
D’oh!
It’s fixed now.
Indeed. The formatting tag buttons here are super buggy on iOS, which I frequently use to do my everyday browsing, and so I instead copied the tag pair with the clipboard and forgot to change the letter!  :palm:
Offline BeBuLamar
« Reply #14 on: July 01, 2022, 07:55:14 pm »
What do you mean? Most electronics stuff come from China. Do we really have choices?
« Reply #15 on: July 01, 2022, 08:00:03 pm »
Yes:
China -> quality control -> distributor with a reputation to protect -> customer
China -> customer
Offline Fungus
« Reply #16 on: July 01, 2022, 08:59:23 pm »
Yes, you have to develop a sense of what's good and what's bad.
I've bought a lot of good stuff on there though. In the long term you'll save a money even if you get a dud every now and again.
« Reply #17 on: July 01, 2022, 09:00:40 pm »
Yeah same as my point above. You have to do your own quality control.
I got a good strip of 10x working new AD8307 log amplifiers from China for $10. They are £15 each here!
Offline Fungus
« Reply #18 on: July 01, 2022, 09:20:18 pm »
I know there's a few things you should never buy on there, eg. 18650 batteries and power MOSFETS.
Anybody have any others...?  :popcorn:
Offline nctnico
« Reply #19 on: July 01, 2022, 09:21:32 pm »
Faringdon should only be buying stuff that is made locally.  :box:
« Reply #20 on: July 01, 2022, 09:24:25 pm »
Quite right too as he can't distinguish the wood from the Treez !  :-DD
Avid Rabid Hobbyist
The following users thanked this post: tooki, bd139
