Hello Electromates,
I am needing to test a batch of Mosfets that just arrived.
I'm wanting to test the Resistance between Drain and Source.
Below is the DataSheet for one of the MOSFETS in question.
For RDS(on) it lists the following......
VGS=10v, ID=10A with a typical reading being .22 ohms and a Max ohms being 0.27 ohms.
The DataSheet does not include a schematic for testing RDS(on), only the parameters.
So, making sure I understand this, it means apply 10v between the Gate and Source Pins, with current at the Drain being 10Amps ?
This circuit is correct for this test?
DataSheet
