Following our collective testing of the 66311B, I picked up a few 66319D's at a local auction by complete fluke.
The 66319D dual output power supply is the top dog of the Mobile DC source line capable of:
• +15 3A output on channel 1
• +12v 1.5A output on channel 2
• -2A sink capability on channel 1
• Built in additional digital voltmeter for checking voltage anywhere in your circuit
• Programmable output resistance of -40 Milli-ohms to +1.0000 Ohms on channel 1 to simulate the internal resistance of a battery. Yes not a typo, you can set the resistance to 0.0015 Ohms or 1.5 Milli-ohms for example. As I will show in later posts it becomes useful in the sinking function.
It is a 2 quadrant unit capable of sourcing positive output voltage on channel 1 and 2, as well as sinking input on channel 1. This for example allows you to supply output power to your DUT using channel 2 and simulate the main battery of your DUT being charged, by sinking current on channel 1, all at the same time.
Keysight Data Sheet is available at the top of this web page:
http://www.keysight.com/en/pd-1000000819%3Aepsg%3Apro-pn-66319D/dual-mobile-comm-dc-source-battery-emulation-dvm?cc=US&lc=engI've been playing around with them all weekend and found them very stable and robust. The damn thing is built like a tank to an obvious very high quality standard.
Please see the attached teardown photo's for your viewing pleasure. I was only able to remove the case and take some limited pics. I did not remove the circuit boards or connectors for more in depth photo's as I have put these units up for sale and don't wish to damage them.
The first photo is a 66311B for comparison
followed by a 66319D overview shot.
Then note the 66319D extra PCB board. Note the main PCB is now fully populated.
Picture of the 66319D transformer
and a 0.25 Ohm resistor.
Suspect the extra board is for the programmable resistance function
Board common to all the models
Enjoy,
Stuart
