Timely thread, as I'm just looking at these too. Here's a table of the main spec points I was interested in:
Vendor | Keysight | R&S | Lecroy | Tek | Lecroy |
Model | MSOS104A | RTO2014 | HDO6104A-MS | MSO56 | WavePro 254HS-MS |
List price (GBP) | £21,000.00 | £19,000.00 | £22,500.00 | £21,618.00 | |
CPU | i5-3550S Quad 3GHz | i5 | i7-2710QE Quad 2.1/3GHz | i5-4400E dual 2.7Ghz | i5-6500 Quad 3.2GHz |
RAM (GB) | 8 | 16 | 16 | Not specified | |
16
OSWindows 10 EnterpriseWindows 7 Embedded StandardWindows 7 Pro 64-bit EmbeddedClosed Linux / Windows 10 cost optionWindows 10
HD240GB SSD200GB SSD80GB /460GB SSD
Screen15"12.1"12.1"15.6"15.6"
Res1024x7681280x8001280x8001920x10801920x1080
External monitorYesYesYesYes4096x2304
InterfacesUSB 3, 1G EthernetUSB 3, 1G EthernetUSB 2, 1G EthernetUSB 3, 1G EthernetUSB 3, 1G Ethernet
Dimensions330H 430W 230D249H 427W 204D291H 400W 131D309H 454W 204D345H 445W 196D
Analog Channels4440-64
Digital channels1616160-2416
BW (MHz) 50OHm at 1mV/div10001000100010002500
BW (MHz) 1MOhm5005005001000
Digital BW (MHz)400400250500
Max BW Upgrade (MHz)80006000100020008000
Noise @ 1mV/div 1GHZ B/W into 50Ohm (uVrms)90100145255155
Noise @ 100mV/div 1GHZ B/W into 50Ohm (uVrms)96016505001610889
Noise @ 1mV/div 500MHz 1MOhm (uVrms)~268130Not specified189
Noise @ 100mV/div 500MHz 1MOhm (uVrms)~6502300Not specified1160
Noise @ 1mV/div 20MHz 1MOhm (uVrms)~120~29Not specified64.8
Vertical divs81010?
GSa/s20/10102.56.2520
Standard memory (MPts) for 4 channels active100505062.5100
Max memory (MPts)40010002501251000
Waveforms per second20001000000500000
Max res (at what b/w?)1216151615
ADC Res108121212
ENOB (what BW? What mV/div?)7.878.47.67.8
SFDR 0dBm at 1GHz (dB)7268
Phase noise at 10kHz (dBc/Hz)-121
Min horizontal timebase (ps/div)5252020020
Input Coupling1MOhm, AC, DC - 50Ohm DC1MOhm, AC, DC - 50Ohm DC1MOhm, AC, DC - 50Ohm DC1MOhm, AC, DC - 50Ohm DC1MOhm, AC, DC - 50Ohm DC
BW Limiters20MHz, 200MHz, User-defined DSP - 500MHz20MHz, 200MHz, User defined20MHz, 200MHz20MHz, 250MHz20MHz, 200MHz, 500MHz, 1GHz
FFTStandardStandardStandardStandard
Intrinsic Jitter(fs rms)10028045060
Jitter analysisTIE requires EZJIT option - £1600TIE requires RTO-k12 optionTIE StandardTIE standardWPHD-JITKIT option
Matlab / User filtersOption - £1900DFP2 option
Compliance testsBroadR-Reach, DDR, eMMC, Ethernet, HDMI 1.4, MHL 2.0, MIPI, MOST, PCI Express Gen4, UHS, USB 2.0, HSIC, XAUIUSB, Ethernet, PCIeAutomotive Ethernet
Decode8B/10B, ARINC, DVI, HDMI, I²C/SPI, JTAG, MIPI, SPMI, PCI Express, RS-232/UART, SATA/SAS, SVID, Ethernet, USB 2.0 3.1 , USB-PD , UFS, eSPI, CAN, LIN, FlexRay, I2S, I3C - All bundled for free for nowLIN, CAN, FlexRay, I2S, MIL-STD-1553, ARINC 429, CAN FD, SENT, MIPI RFFE, MIPI D-PHY, MIPI-M-PHY, Manchester, NRZ, 8b10b, MDIO, USB, Spacewire, PCIe, CXPII2C, SPI (SPI, SSPI, SIOP), UART-RS232, CAN1.1, CAN2.0, CAN FD, LIN, FlexRay, MIL-STD-1553, AudioBus (I2S, LJ, RJ, TDM), USB1.x/2.0I2C, SPI, RS-232, CAN, LIN, FlexRay, USB 2.0, Ethernet, I2S, LJ, RJ, TDM, MIL-STD-1553, ARINC 429
Passive Probes1 per channel - 500MHz - 9.5pF1 per channel - 500MHz - 9.5pF1 per channel - 500MHz - 10pF1 per channel - 1GHz. 10:1 and 2:1 - 4pF
Diff probeN2750A - 1.5GHz - 2:1 - 0.7pF - 15V- 200kOhm - £2000RT-ZD10 - 1GHz - 10:1 - 0.6pF - 8V - 1MOhmZD1000 - 1GHz - 1pFTDP1500 1.5GHz - 1:1 10:1 - 0.85V 8V - 1pF - 200kOhm - £3700
Power probeN7020A - 2GHz - 24V - 1:1 - 50KOhm - £2000RT-ZPR20 - 2GHz - 1:1 - 60V - 50kOhmRP4030 - 4GHz - 30V - 1.2:1 -0.1uFTPP0502 - 2:1 - 12pF - 500MHz
ARBNoOption RTO-B6 - 100MHzNoOption - 50MHz- £1000
NotesH/W buttons for all channelsDigital connector at the back No peak detect?BW limit at <4mV/div 50Ohm
Notes: List price for MSO56 includes digital probes to make it equivalent. 10GSa/s rate for HD6104A is interpolated, actual rate appears to be 2.5. Other options are available, I've just listed the ones I'm interested in. Keysight cliam measured ENOB for LeCroy is < 8. E&OE. Corrections welcome
Probably between the Tek and Agilent for me at the moment. Tek looks pretty good apart from the noise figures and the eye watering cost of some of the extras. The passive probes sound good. The Agilent seems to have better performance and more extensive s/w options. I'd be interested to hear more from people who say it isn't necessarily the best as a general purpose scope and why?
If anyone has an MSOS104A, I'd like to know what the noise floor is when the BW is limited to 20MHz at 1mV/div.
