I am the proud owner of an R&S RTB2004.
Connected to the internal network of my home, using the web browser integration, remote control of this oscilloscope is very convenient.
I have now found out that when creating screenshots, the system clock of this oscilloscope does not synchronise with the system clock of e.g. the computer(s) on the network. After leaving the device switched off for several weeks, it appears that the clock is several minutes behind.
There is no possibility in the menus to synchronise this time or to synchronise it with e.g. the router acting as NTP server in the network.
The clock can only be set to a time.
This is quite a bad thing, as time synchronisation within a network is essential for many devices.
Perhaps there is a possibility of using a SCPI command to synchronise the system time to the DHCP server/router acting as an NTP server.
I have searched but cannot find a solution.
Does anyone know of a solution?
