I did a quick check of all four the the DM502s, though I didn't check the temperature function on the two unit so equipped.
#340 - broken ground jack, one digit of the display not working, no apparent internal damage, current measurement problem
#140 - broken ground jack, no apparent damage, DC voltage and resistance measurement problem
#617 - good physical condition, resistance and current measurement problem
#748 - good physical condition, no apparent problems
These four units came from four different sources. The first two, with the temperature option, are the most beat up. Going to go straight to #748 for check out and calibration as described in the manual.
