Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Transistortester not working
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Transistortester not working (Read 828 times)
panoss
Frequent Contributor
Country:
on:
April 26, 2020, 02:58:52 pm »
I 've built
the well known transistor tester
but it 's not working.
With
this firmware
(I 'm using an ATMega8).
This is what it displays when I have nothing connected on the test points and press the button:
And this with a resistor connected (at the test points):
As you can see it does not really measure anything.
I have checked for cracks on tracks, shorts, cold solderings, anything. But haven't found any fault.
Any help is welcome.
(I 'm using a 4MHz crystal instead of 8MHz as per the original design. I 've added the frequency in the code)
Last Edit: April 26, 2020, 03:08:00 pm by panoss
Logged
CDaniel
Country:
Re: Transistortester not working
Reply #1 on:
April 26, 2020, 05:02:13 pm »
You should try to find an 8MHz quartz and use the original code ...
And I don't see how option bits should be set , Atmega8 has CKDIV8 , clock divided by 8 or not
Last Edit: April 26, 2020, 05:15:56 pm by CDaniel
Logged
panoss
Country:
Reply #2 on:
April 26, 2020, 07:16:00 pm »
But this is the original code, I just added the frequency:
Code:
[Select]
#define F_CPU 4000000UL
Logged
CDaniel
Country:
Reply #3 on:
April 27, 2020, 12:23:21 am »
I mean the original hex provided . I don't use that system but after a change the program is recompiled and a different hex should result ... The compiler has to know what timings to change for the new frequency , pretty much everything
Last Edit: April 27, 2020, 12:28:44 am by CDaniel
Logged
panoss
Country:
Reply #4 on:
April 27, 2020, 06:34:12 am »
The result was the same with the original hex file (and other hex files I tried, e.g.
this one
Last Edit: April 27, 2020, 07:09:08 am by panoss
Logged
panoss
Country:
Reply #5 on:
April 27, 2020, 03:27:18 pm »
Finally...it was a bad soldering...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
