Author Topic: Trigger on UART pattern  (Read 1629 times)
Offline MotoDanTopic starter
« on: June 03, 2023, 07:46:26 pm »
Hello all,
I’m in the market for a new scope which has the capability of triggering (and decoding) on a UART pattern. Like most lower entry scopes, my Rigol 2000 series scope will only allow for a single data byte for triggering. I would like to be able to trigger on a string of data. A minimum of 10-20 bytes would be nice. It doesn’t look like the Rigols or Siglents have the multi-byte trigger capability. I did find a high-end Agilent 9000 series, but they are way out of my budget which under $2k.
Online langwadt
Re: Trigger on UART pattern
« Reply #1 on: June 03, 2023, 08:07:06 pm »
Hello all,
wouldn't take many line of code to do as an addon with cheap micro connected to ext-trig
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #2 on: June 04, 2023, 12:00:21 pm »
We actually support multi-byte UART triggering on all of our oscilloscopes, but even our entry level RTB2000 oscilloscope with the UART option (K2) lists at about 2500 USD.
https://www.rohde-schwarz.com/us/products/test-and-measurement/oscilloscopes/rs-rtb2000-oscilloscope_63493-266306.html
Edit: the RTB only supports patterns up to 4 bytes.
« Last Edit: June 04, 2023, 12:04:08 pm by pdenisowski »
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
« Reply #3 on: June 06, 2023, 02:44:41 pm »
I thought about that and may end up with that approach in the interim. Just wanted to check if any scopes had this feature before upgrading mine.
Thanks!
