Hi mawyat,
Thank you for the suggestion, even more am monster in every regards
The beef question will be, how the KS 336xxA dual channels models really performs, as with PN & Jitter over the full freq. range and only on Square wave or even on Sine wave too.
Siglent and coo branded of 2K or 6K model for my use show a high jitter figure and may a higher THD figure... Jitter as seen on the SSA (200Hz Span 1 Hz RB at 10Mhz) do the synthesizer crappy solution, as seen IMHO as on the SDG2k... the 6K model may similar.
In other words go cheap and crappy or expensive without knowing the result
All nice videos seen do not help in any regards
While real tests for the KS 336xxA models seams to be as none existing.
Or one offer with PM message the help out
Hp
