Author Topic: UNI-T UDB3000S Series: UDP3305S / UDP3305S-E  (Read 18017 times)
Offline Pfriemler
Re: UNI-T UDB3000S Series: UDP3305S / UDP3305S-E
« Reply #100 on: March 01, 2024, 07:43:17 pm »
For all German/European users that are interested in the S-E version:
https://www.pollin.de/p/uni-t-labornetzgeraet-udp3305s-e-4-kanal-programmierbar-328-w-353199
379 Euro, some promotion code or sell actions may clear the shipment costs to Zero.
once you do it right, it works :-)
The following users thanked this post: thephil, flo.b
Offline thephil
    • Techbotch
« Reply #101 on: March 01, 2024, 08:15:21 pm »
And someone told me that you can get the S-E version for 342€ right now through the UNT-T subsidiary in Augsburg, Germany. But you have to ask them for the "promotion" price.
It's never too late to have a happy childhood!
The following users thanked this post: flo.b
Offline elemakil
« Reply #102 on: March 09, 2024, 08:29:28 pm »
Hey thephil,
can you shed any more light on the promotion that UNI-T is offering? Do I have to contact them through the webstore or Email (if so, which of the Emails listed on their homepage is appropriate for this request?). I'd appreciate some more information as the UDP3305S-E would be a great bargain at this pricepoint.
Best,
Offline thephil
    • Techbotch
« Reply #103 on: March 10, 2024, 01:16:45 pm »
Apparently, UNI-T has/had(?) advertised a 20% discount in the US. Someone told me that he saw that and simply asked the German UNI-T people about it and was offered the price I mentioned. He wrote or talked to these guys:
Uni-Trend Technology EU GmbH
Affinger Str. 12
86167, Augsburg
+49(0)821 710 498 26
service-eu@uni-trend.com
I don't know if it still works but can't hurt to ask.
« Last Edit: March 10, 2024, 01:18:41 pm by thephil »
Offline Duglum
« Reply #104 on: March 14, 2024, 12:29:35 pm »
I wrote them and they replied with a discount code ("THANKYOU10") for their Shop.
The email claimed the code will only be valid until tomorrow.. but i kinda doubt it.
Anyway, it brought down the price for the UDP3305S-E to 296.10€ net (352.36€ gross for me, which means they applied the 19% german VAT).
Shipping was free. The shop also said delivery time will be 2-4 business days, so they most likely send it from Augsburg.. international express from china for such a heavy item would probably be far too expensive to offer it for free.
Oh and, did anyone ever try to replace the 14bit DAC with the DAC8562 chip iAleks mentioned earlier in this thread? Replacing the firmware with the "S"-one sounded like it was no problem. Don't really need that type of precision and would probably not do it before warranty runs out, but it would be nice to have the option. :)
« Last Edit: March 14, 2024, 12:34:30 pm by Duglum »
Offline voltlog
    • VoltLog
« Reply #105 on: April 18, 2024, 07:08:06 am »
For those wondering if they can upgrade the UDP3305S-E to be a higher spec UDP3305S just by replacing the ADC/DAC chips (ADS1118 / DAC8562 ) and flashing new firmware, UNI-T says "It's not possible!"
At Embedded World 2024 in Nuremberg, I had the opportunity to talk to the senior engineer in charge of the team that developed this PSU at UNI-T and asked him if it would be possible to swap the ADC/DAC chips and flash different firmware for the conversion.
Our conversation was very limited because he only spoke little english but what I could understand is that there are two problems that one will face: there are other smaller changes on the PCB apart from ADC/DAC chips and then there is the very important calibration which is only designed to be done at the factory, not accessible to the user.
BTW I also have a reaview & teardown video of the UDP3305S.
https://youtu.be/h7XDSfOQJHI
https://youtu.be/d056TNS9aa8
The following users thanked this post: thm_w, tonyalbus
Offline mws
« Reply #106 on: April 18, 2024, 09:40:32 am »
I also saw the offer here. Unfortunately, I can't find a way to enter the code on the UNI-T website.
Offline pope
« Reply #107 on: April 18, 2024, 12:16:28 pm »
It's been removed.
Offline tonyalbus
    • My Channel
« Reply #108 on: April 20, 2024, 07:49:30 am »
A while ago i received new firmware 1.12 , i see it not on their website, so decided to post it here.
Also the change log is very limited on there website, so i have here the one i received.
V1.12 update:
Optimize list output function.
V1.11 update:
Strategy for changing the output setting value and protection value: The output setting value can be made greater than the protection value.
V1.10 update:
1. Optimize SOCKET connection mode;
2. Solve the bug of occasional loss of sent data in SOCKET connection.
V1.09 update:
1. Add SOCKET connection mode, the connection port is 5025;
2. Optimize network connection.
V1.08 update:
1. Improve SCPI standards;
2. Add memory-related communication commands;
3. Optimize the local file manager and display the applicable channels of this list file and delayer file before the file name.
V1.07 update:
1. Add large font display mode.
V1.06 update:
1. Add power-on output function.
V1.05 update:
1. Added new communication commands to adapt to the NeptuneLab platform;
2. Added German to multiple languages.
V1.03 update:
1. The time resolution of timer and delayer is upgraded to 0.1 seconds.
2. The change strategy is: when the output setting value is greater than the reasonable value, the current value will not be changed.
3. An "error status" is added to the list output running status. When the output value set by the list is greater than a reasonable value, an error will be reported.
4. Add a shortcut for setting UI language.
Upgrade method:
1. Select the upgrade file according to the model and put it in the root directory of the FAT32 format U disk (the file name cannot be modified);
2. Insert the USB flash drive into the machine to be upgraded (power off);
3. Press and hold the "UTILITY" button to turn on the computer and start the upgrade;
4. After the upgrade is completed, manually restart the machine.
Video how to:
The following users thanked this post: hfleming, Mortymore
Offline thm_w
  • Non-expert
« Reply #109 on: April 22, 2024, 10:10:09 pm »
That is cool that you asked.
I guess the ~$10 BOM difference is enough for them to make two different products (2pc ADS + 2pc DAC?). Other manufacturers wouldn't have bothered.
Teardown was good to see, you can always post the full link:
Offline pope
« Reply #110 on: April 25, 2024, 02:22:13 pm »
Looks like they increased the prices. I was about to pull the trigger but now I'm gonna have to look for a different brand. Oh well...
« Last Edit: April 25, 2024, 07:45:08 pm by pope »
Offline BillyO
« Reply #111 on: April 25, 2024, 03:30:09 pm »
Looks like the increased the prices. I was about to pull the trigger but now I'm gonna have to look for a different brand. Oh well...
Yeah, they've given so many of them away lately to "influencers" they have to increase the price to make up for it.
« Last Edit: April 25, 2024, 04:26:11 pm by BillyO »
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
The following users thanked this post: pope
Offline 0x2102
« Reply #112 on: April 30, 2024, 10:14:52 pm »
Hi there,
I own the UDP3305S-E for about a week now and overall I enjoy the PSU. 4 ports are great, build quality seems to be good, usability is good. I can't judge the accuracy or other technical specs.
Coming from RD buck converters there are two things I don't like that much:
1.) Fan noise. It seems like everybody it is saying is quieter than XYZ, but for me it's quite loud, even at idle and it only get's worse from there.
2.) Running the power supply at 12V / 5A: outputs 60W and it draws around 190W from the wall. Looks like PSU itself requires about 20W to operate, the rest is inefficiency due to the fact that it is a linear power supply?
Standby power consumption seems to be 0.2W - which is great and that's how it should be. I have seen power supplies that draw 6W - 8W in standby. That is a no-go in 2024.
I was thinking of replacing the fan with a Noctua but 1 low noise fan will probably not provide enough airflow when it has to dissipate > 100W. Heatsink seems too small for that.
Call me crazy but I might not keep it just because of the fan noise.
Offline thm_w
  • Non-expert
« Reply #113 on: May 01, 2024, 12:39:23 am »
It does seem oddly poor efficiency (35%) but its not far off from whats expected from a linear PSU. Unless you have a switching pre-regulator or lots of transformer taps its going to generate heat. You can play with the output voltage and see where the taps change over and where the efficiency drops.
Comparison DP900:
- 24W at idle
- 30V 61W output, 130W from wall = 58%
- 24V 40W output, 92W from wall = 59%
- 12V 10W output, 48W from wall = 42%
Don't think its crazy. These instruments are usually targeted at workplace use, where in an office fan noise of this level (I assume) is normal and tolerable. Though some are even too loud for workplace use (rigol dg800p). If you are a hobbyist at home, it may be unacceptably loud. Did you measure dB?
What are the specs of the original fan?
Don't think noctua is an optimal replacement just because its a good brand, it may or may not be a good swap.
Offline tonyalbus
    • My Channel
« Reply #114 on: May 01, 2024, 06:24:11 am »
Yes it as 3 or 4 tabs, you can hear the relays when changing the volatges, i thought i heared 3 or 4 clicks going from 0 to 30,
the good thing is, on lower voltages it does not have to dissipate to much power and heat, becouse it switched to a lower voltage on the transformer.
that is also the reason the heatsink does not have be to that  big.
and i am one of those who found it silent compared to my other PSU's in the lab.
i am running the latest FW, 1.12 maybe they also did something with the fan control
« Last Edit: May 01, 2024, 06:27:33 am by tonyalbus »
Offline thephil
    • Techbotch
« Reply #115 on: May 01, 2024, 08:29:53 am »
In my testing, I found four relay switching events at roughly 5, 11, 17.5 and 25V. That would translate to five separate transformer taps. So you would expect best efficiency just above those voltages.
Offline 0x2102
« Reply #116 on: May 01, 2024, 06:19:23 pm »
First thing I did was to upgrade the firmware to 1.12
I think the noise level is comparable to the DP900. It's not loud but it's also not silent as it could be, especially when the outputs are turned off. It's that steady fan noise I can hear 5 meter away from the unit.
Sometimes I would leave my other PSUs running when I google/review something but not with this one. It will remind you that it's running and I turn it off and back on 20 minutes later when I need it.
Comparison DP900:
- 24W at idle
Here are my UDP3305S-E numbers:
- 16W at idle
- 30V 60W output, 128W from wall = 54%
- 24V 40W output, 92W from wall = 53%
- 12V 10W output, 48W from wall = 31%
Did more testing and it seems like higher current has a big impact on efficiency. It looks like the best efficiency is before it has to switch to the next transformer tap - which kind of makes sense due to the higher load on the tap.
10W - 22.4W output results all in the same 72W from the wall. 2A current from 5V to 11.2V - right before the switching point.
Offline ncsm
  • Country: br
« Reply #117 on: May 01, 2024, 06:33:20 pm »
First, I apologize if this is out of context, but I was wondering if anyone could help with how to enter calibration mode? Best regards
