Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
UNI-T UT372 tacho, works best off-angle ???
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: UNI-T UT372 tacho, works best off-angle ??? (Read 675 times)
Circlotron
Super Contributor
Country:
on:
December 11, 2018, 01:14:55 pm »
Got one of these today:
https://www.ebay.com.au/itm/UNI-T-1-set-Red-Gray-UT372-Digital-Display-Speed-Tester-18-4-5-6-3-4CM-N1U9-/283142056140?nordt=true&orig_cvip=true&rt=nc&_trksid=p2047675.m43663.l10137
Didn't seem to work very well at all initially. Then I discovered that if you angled the beam 45 deg to the reflective surface it ran quite well. Question is - why wouldn't it work when the laser is pointing directly at (perpendicular to) the reflective surface? It showed a reading 20 or 30 times higher than actual rpm and very unsteady.
As far as accuracy is concerned it's pretty good. Connected a red LED to a function generator and aimed it at the receiver phototransistor. At 90,000 rpm equivalent (5-digit display) there was way less than 1 rpm error, judging by how long it spent on 90,000 vs 89,999.
Last Edit: December 11, 2018, 10:13:47 pm by Circlotron
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
