A few years ago, I got hold of a TEK 2236A. When I was young, it was my dream, and I couldn't even imagine buying one.
It worked right out of the box, and it worked well. After three days, one of these capacitors exploded, making such a smell that it took days to get rid of it in my room.
I replaced it with a similar one I had at home; it won't last another 50 years, but I don't need it to last another 50 years; I won't be here.
I wanted to do the famous recapping operation, but I saw that there are schools of thought that disagree.
Honestly, if I had found a ready-made kit, either from Tektronix or some reputable lab somewhere in the world, I would have done it with patience and pleasure, but searching for all the spare parts one by one from different online sellers, with the risk of buying some unsuitable components, doesn't seem like a good idea.
So far, it's been working for two years. I turn it on periodically for 10 minutes at least once a month and look at it with satisfaction.
Good advice is to use the variac with a great care. But here, as with the "recap," there are opposing schools of thought, and some, not having an expensive variac, resort to the trick of using an old incandescent light bulb with enough wattage to operate the device but capable of limiting the damage caused by any failure of an old component.
After blowing the input fuse a couple of times, if you can find one, I'd use an incandescent light bulb with a wattage of, say, 2-3 times the oscilloscope's power draw. If the light bulb doesn't light up and the oscilloscope does, you're in luck.
If the light bulb lights up, turn everything off immediately and perhaps you'll have time to see the component that was starting to burn out without any disastrous damage.
