hello friends, I am back
Now see a old glowing Tek what can sniff in the UHF area.
Tektronix Type 564 storage oscilloscope, equipped with sampling unit plugins.
The setup is this:
Tek 564
scope mobile 201 "D" with plugin housing
plugin 3B3 time base
plugin 3B4 time base
plugin 2A61 high sensitive differetial input plugin what reads from 10µV/div
plugin 3A6 (have 2 pcs) normal input plugin, have 2 to use the second for XY operation.
plugin 3T2 sampling sweep, this is a very special time base for using sampling system
plugin 3S2 is a dual channel sampling input plugin with 2 slots for sampling heads
sampling head s1
sampling head s2
sampling head s3 the complete set including attenuators
sampling head s4 (have a rise time of smaller then 25 picoseconds)
about 56x series from Tek: this scopes have no own deflection amplifiers, they are part of the plugins ! So when you own more the one of them, you have to decide by every plugin you have there which of your 56x scopes is the owner of that bec. the plugin have to be calibrated to work with the CRT.
pick up: a good loadet car...
Sampling head S3 complete set, and the S2
some of the plugins
here is the 2A61 Diff, I need urgend the plug for that, a Bendix 8-4 male.
And the sampling unit including 2 of the heads...
the 564 inside.
the scope was in a smokers laboratory of Telefunken
the Restoration, washing...
a new old 564?
Plugins.
a dirty scope mobile, washing
And here is the Tek
A special look inside the 2A61...
the large can is a coupling C, used for the lowest frequency of 0,06Hz... Tek have placed a bipolar 20.000µF/3V. In the both blue metal cases are selected pairs of nuvistor tube. The litte fram is soft mounted with rubber to reduce microphonic effects from the case.
A highlight of the old engineers
greetings
Martin
