EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Voltage and current in 6:1 balun for sensitivity measurement
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Voltage and current in 6:1 balun for sensitivity measurement (Read 1730 times)
AllTheGearNoIdea
Supporter
Country:
on:
April 22, 2017, 07:12:37 am »
Hi all need some advice on trying to do a sensitivity measurement in a VHF fm receiver. This is designed to have a 300 ohm balanced feeder and I only have 50 ohm unbalanced outputs on my signal generator. I would normally build a resistive pad to Match impedance. The impedance and the losses are easily calculated in a resistive pad but this won't produced a balanced feed. If I build a 6:1 balun I'm not sure about the voltage levels on the output side of the balun. Will it be 6 times greater or smaller. Even if I build something not sure how I could calibrate it back so my sensitive measurement are in anyway accurate. Perhaps I'm over thinking can anyone give some advices on how to do this. Assume I have reasonable amount of test gear, just no idea how to use it.
Thanks
Last Edit: April 22, 2017, 07:15:16 am by AllTheGearNoIdea
Logged
AllTheGearNoIdea Where Its All About The Gear
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: Voltage and current in 6:1 balun for sensitivity measurement
Reply #1 on:
April 22, 2017, 07:17:10 am »
Voltage ratio (turns ratio) is sqrt(impedance ratio).
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
AllTheGearNoIdea
AllTheGearNoIdea
Supporter
Country:
Reply #2 on:
April 22, 2017, 07:24:53 am »
Ok thanks, I guess I still need to try and measure the output voltage side, for calibration purposes. I'm wondering how the material losses and construction will affect the calculated voltages etc.
Regards Chris
Last Edit: April 22, 2017, 07:39:00 am by AllTheGearNoIdea
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
