Author Topic: VOLTCRAFT DOV series  (Read 108893 times)
0 Members and 57 Guests are viewing this topic.
Online Aldo22Topic starter
« on: June 02, 2025, 04:14:16 pm »
Links to Important Information about the DOV702/DOV704
Firmware
Firmware V1.0.1.0.17: https://www.eevblog.com/forum/testgear/voltcraft-dov-series/msg6290906/#msg6290906
Firmware V1.0.1.8.2: https://www.eevblog.com/forum/testgear/voltcraft-dov-series/msg6306016/#msg6306016
Android
Install from unknown sources: https://www.eevblog.com/forum/testgear/voltcraft-dov-series/msg6282254/#msg6282254 ff.
ADB, Root: https://www.eevblog.com/forum/testgear/voltcraft-dov-series/msg6284872/#msg6284872 ff.
Model change: https://www.eevblog.com/forum/testgear/voltcraft-dov-series/msg6285774/#msg6285774 ff.
Prerequisites
 On the DOV:
 - A terminal emulator, such as https://f-droid.org/de/packages/com.termoneplus/
 On a computer:
 - Android SDK Platform-Tools
 - Python 3
Hardware
Fan:
NF-A60x15 FLX: https://www.eevblog.com/forum/testgear/voltcraft-dov-series/msg6287860/#msg6287860
NF-A6x15 PWM: https://www.eevblog.com/forum/testgear/voltcraft-dov-series/msg6310028/#msg6310028
Ripple:
Removing the buffer: https://www.eevblog.com/forum/testgear/voltcraft-dov-series/msg6296726/#msg6296726
SL75 mod.: https://www.eevblog.com/forum/testgear/voltcraft-dov-series/msg6305216/#msg6305216 ff.
To be continued...??
External Links
Conrad Documents & Downloads
Owon  Documents & Downloads
mikrocontroller.net
Original first post for reference
Does anyone know what this is or who manufactures it? (Owon, Uni-T, Rigol...).
The specs don't sound too bad:
12-bit high resolution ADC
Real-time sampling acquisition 50,000 wfms/s, Segment acquisition 700,000 wfms/s
Sampling rate: Single channel (1.25 GSa/s), Dual channel (625 MSa/s or 1.25 GSa/s), Full channel (625 MSa/s)
17.78 cm (7 inch) multi-touch capacitive screen, supports gesture control
Channel memory depth: 50MP
https://www.conrad.com/en/p/voltcraft-dov704-digital-70-mhz-4-channel-1-25-gs-s-50-mp-12-bit-digital-storage-dso-1-pc-s-3350782.html
2583814-0
« Last Edit: August 13, 2026, 10:27:05 am by Aldo22 »
The following users thanked this post: evava, Martin72, the Chris, CeeJay
Online tatel
Re: VOLTCRAFT DOV series
« Reply #1 on: June 02, 2025, 04:35:03 pm »
I would go for the similar siglent DSD804X HD to get 2 GSa/s and 500,000 waveforms/s for just a little bit more?
https://www.siglenteu.com/digital-oscilloscopes/sds800x-hd-digital-storage-oscilloscope/
« Reply #2 on: June 02, 2025, 04:43:17 pm »
Thank you, but that was not my question.  ;)
Besides, it's not that simple.
The Voltcraft has a slightly better sampling rate in 4-Ch mode (4x625 MSa/s vs 4x500 MSa/s for the Siglent) and Dual Channel mode (2x1.25 GSa/s vs 2x1GSa/s).
« Last Edit: June 02, 2025, 04:48:52 pm by Aldo22 »
Offline tunk
  • Country: no
« Reply #3 on: June 02, 2025, 04:52:51 pm »
Owon ADS800A or ADS900A.
The following users thanked this post: mcinque, Aldo22
Offline electr_peter
  • Country: lt
« Reply #4 on: June 02, 2025, 05:04:37 pm »
Yes. But why does it look very similar to Rigol DHO800 series? +/- same case molding with minor differences between Rigol and VoltCraft/Owon. It could be copy inspired design or same designer as Rigol.
« Last Edit: June 02, 2025, 05:10:29 pm by electr_peter »
« Reply #5 on: June 02, 2025, 05:07:52 pm »
Yes, these look similar.  :-+
But the sampling rates don't quite fit.
Offline kmoonwalker
« Reply #6 on: June 02, 2025, 05:16:33 pm »
it looks that it is Owon ADS800A series
regarding parameters given by manufacturer I would strongly recommend to read carefully the description:
"All digital DOV oscilloscopes from VOLTCRAFT operate at a maximum sampling rate of 1.25 GSa/s. The real-time recording is 50,000 WFM/s and the segment recording is 700,000 WFM/s"
from that Conrad scope page
Siglent is on similar price level but faster real time wfm/s so you will see more often that erratic signal occurence straight on screen not just diggin into memory...
Owon was never excelling in wfs/s rates (especially when you turn on a bit of things) and only interesing scope from current offer for me was
https://www.owontechnology.eu/product/1312929/owon-xds3104ae-100mhz-4-channel-1gs-s-oscilloscope
and his 200MHz variant (with a bit more wfm/s) but they are more expensive (thou I think that 3104ae is worth adding money to it if you wanna Owon - I used it a bit at friends company and it is non brainer reasonably simple to use scope which surprisingly works very nice and 14 bit seems to do some job.
but Siglent offers more in capabilities of math and other details so all depends what you need it for
low models have "flashy specs" but reality later is a bit bitter usually and that price level on Conrad is not something special to say ;)
Online tatel
« Reply #7 on: June 02, 2025, 05:20:46 pm »
4x625MHz=2.5GHz? Not sure about your math, or perhaps about Voltcraft missing the opportunity to provide us with some hype. Even if true, anyway I would feel much more comfortable putting my money into the Siglent. I would say, it's a much more tested device, from a much more reputable brand. For me, it would really be that simple. But, of course, those that don't explore, don't find any treasures.
BTW, congratulations for that Hameg you got. These are nice scopes IMHO.
« Reply #8 on: June 02, 2025, 05:24:43 pm »
Yes, I have noticed that.
But Rigol DHO800 has even less (30,000 wfms/s) if I read that correctly.
« Reply #9 on: June 02, 2025, 05:29:38 pm »
I guess it's 1.25GSa/s for Ch1+2 and the same for Ch3+4.
So if you use Ch1+3 you get 1.25GSa/s for each.
But maybe the information is wrong.  :)
Thanks!
« Last Edit: June 02, 2025, 05:32:54 pm by Aldo22 »
Offline kmoonwalker
« Reply #10 on: June 02, 2025, 05:34:42 pm »
From Rigol I have old 1054Z and it has same specs so I dunno what they actually thought not improving the basic parameter only adding 12 bits processing - rest of the World moved on - plus firmware on new models is not as good as it could be with lil more effort and testing before the release :/
Such wfm/s was good (nice actually) back then when I got my 1054Z but nowadays if you wanna spend money and this is the scope you will use for next few years it is worth considering what are your real needs and what they will be in not distant future and if adding a bit more is an option or not.
Oscilloscope for few hundred to +/-1500 euro will be your everyday workhorse and perhaps in future you will need something more advanced as second one (or that first good purchase will suit you for like next decade or longer - just spend time and choose wisely).
« Reply #11 on: June 02, 2025, 06:03:07 pm »
Thanks!
By the way, just to avoid any misunderstandings, I'm not looking for a new scope.
I was just looking for something else on the Conrad website today and then stumbled across these scopes.
I just thought: Huh? What is that?
That's all.  ;)
« Last Edit: June 02, 2025, 06:05:05 pm by Aldo22 »
Offline kmoonwalker
« Reply #12 on: June 02, 2025, 06:09:28 pm »
Voltcraft rebrands usually cheap things or not very pricey - but from time to time they have something not bad like Metex made DMMs - nayway I purchase there usually when they have good discount offer or so
« Reply #13 on: April 17, 2026, 07:22:51 pm »
Conrad is currently selling the DOV704 for €199, including VAT (Germany).
That's really cheap for the specs and features it has.
https://www.conrad.de/de/p/voltcraft-dov704-digital-oszilloskop-70-mhz-4-kanal-1-25-gsa-s-50-mpts-12-bit-digital-speicher-dso-1-st-3350782.html
« Reply #14 on: April 20, 2026, 02:26:46 pm »
It's getting cheaper and cheaper.
We're talking about 4-channel, 2 x 1.25 GSa/s, 50 Mpts, 12-bit
https://www.voelkner.de/products/11864782/VOLTCRAFT-DOV704-Digital-Oszilloskop-70MHz-4-Kanal-1.25-GSa-s-50-Mpts-12-Bit-Digital-Speicher-DSO-1St..html
€179.10, including tax and shipping  :palm:
Online Martin72
« Reply #15 on: May 14, 2026, 08:30:36 pm »
Let´s continue here...
From https://www.eevblog.com/forum/testgear/choosing-oscillosope-for-diy-purposes/msg6261278/#msg6261278
Quote from: Aldo22
The VOLTCRAFT DOV series is identical to the OWON ADS800A series.
Yeah, you're right.
Still, I think there's a lot of the Rigol DHO800/900 under the hood.
The Uni-T series also looks a lot like Owon/Voltcraft.
Let's see what comes out next week—I'm curious. ;)
The following users thanked this post: egonotto, Aldo22
« Reply #16 on: May 14, 2026, 09:06:10 pm »
I wonder if the knobs on the Voltcraft aren't a little too big, making the space between them a bit tight for your fingers.
The Owon looks a bit more spacious in that regard.
The following users thanked this post: Martin72, RogerG, atrophicinterludes
Online Martin72
« Reply #17 on: May 14, 2026, 09:13:58 pm »
LOL, actually, that could be a problem with my clumsy fingers... ;)
Online KungFuJosh
  • TEAS is real.
« Reply #18 on: May 14, 2026, 09:50:41 pm »
The voltcraft looks like a tool, and the owon looks like a toy. Funny that they're the same thing. ;)
Best Continuity Tester Ever
« Reply #19 on: May 15, 2026, 03:12:06 pm »
You could say that.
When viewed from the side, you can see the ridges on the buttons.
It almost looks high-quality, but it’s probably just cheap plastic.
Online KungFuJosh
  • TEAS is real.
« Reply #20 on: May 15, 2026, 05:43:23 pm »
Plastic is a fine choice. Nothing wrong with being insulated from the scope. ;)
Offline PhilRépartout
« Reply #21 on: May 16, 2026, 10:05:39 am »
impressive price for DIY work, even more if these are upgradable with some hack ...  :popcorn:
Online Martin72
« Reply #22 on: May 16, 2026, 10:46:58 pm »
That can almost certainly be hacked.
If my assumptions are correct and the Voltcraft/Owon is essentially a Rigol DHO900, then the price of the Voltcraft scopes is nothing short of insane.
The DHO800/900 series has its “inherent” drawbacks, because it’s from Rigol.
But basically, these are good 12-bit systems for the price (DHO800).
If you can get one for €180 (Voelkner) right now, that’s a real bargain.
According to the tracking information, my Voltcraft Scope is supposed to arrive as early as next Monday.
As you can imagine, I’m not going to rely on the 3-year warranty.... ;)
The following users thanked this post: danno_cj, Aldo22, PhilRépartout
« Reply #23 on: May 17, 2026, 06:51:21 am »
dho900 series specs seems differents to me...
1 x 1.25 GSa/s, 2x 625MSa/s, 4x 312MSa/s,
Compared to Volcraft, 2 x 1.25 GSa/s, 4x 625MSa/s
double Asics chips  here ?
« Reply #24 on: May 17, 2026, 08:28:35 am »
If my assumptions are correct and the Voltcraft/Owon is essentially a Rigol DHO900, ...
I don't see many similarities there.
The VC DOV704 / OWON ADS804A has a better sampling rate in multichannel mode and greater memory depth (50 M) than the Rigol DHO804.
The UI looks different, too, as does the PCB, at least at a glance.
What makes you come to that conclusion?
« Last Edit: May 17, 2026, 08:37:45 am by Aldo22 »
