Author Topic: What's going on with my Fluke 117 meter?  (Read 7578 times)
Offline AxtmanTopic starter
« on: May 12, 2017, 06:21:47 am »
If I hold down the "HOLD" button on my Fluke 117 meter and turn the selector switch from "OFF" to "AUTO-V LoZ" my meter displays a weird message "FCEY". When I release the "HOLD" button the backlight starts flickering on and off!
I looked through the Fluke user's manual and did not see anything to indicate what this might be.  What the heck is going on?!
Offline RobertHolcombe
Re: What's going on with my Fluke 117 meter?
« Reply #1 on: May 12, 2017, 06:54:48 am »
I'm not familiar with the 110 series meters, however all flukes I've used have different power-on features when holding each of the buttons during power on, and sometimes a different function or display at each range on the selection dial. These are usually recorded somewhere, in the manual or sometimes even on the back of the meter itself.
Functions like disabling auto power-off, auto backlight-off, no beeps, LPF enable/disable, version check, etc
Flashing backlight sounds a bit odd.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #2 on: May 12, 2017, 07:10:08 am »
Factory Calibration Erase?
Offline Fungus
« Reply #3 on: May 12, 2017, 09:10:03 am »
According to the manual (page 9) the "HOLD" button is used to display all segments at power-on.
Does it do something different when you go to low-Z? Only Fluke knows.
My advice? Don't do it.
Offline Shock
« Reply #4 on: May 12, 2017, 11:53:55 am »
The same flickering backlight occurs on the Fluke 114, the message displayed is "FCTY" though not FCEY.
Offline X
    • This is where you end up when you die...
« Reply #5 on: May 12, 2017, 01:03:25 pm »
Might be worth contacting Fluke as this sounds like a fault within the meter, or an undocumented mode.
On my Fluke 28-II this activates every single segment in the entire display until you let go of the button and then the meter starts up and operates normally.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #6 on: May 12, 2017, 01:09:39 pm »
FCTY is restore to factory defaults on a 187.
There is only 1 segment different between FCTY and FCEY...
« Reply #7 on: May 12, 2017, 03:39:36 pm »
Here is the "FCEY" screen message.
How do I compress a video on my Iphone 6 in order to post it? I want to show you the flickering of the backlight.  Thanks!
Offline Fungus
« Reply #8 on: May 12, 2017, 03:49:03 pm »
That's not an 'E', that's a 'T'.
Offline retiredcaps
« Reply #9 on: May 12, 2017, 05:24:52 pm »
Agree, that is a lower case letter "t".
Offline BMack
« Reply #10 on: May 12, 2017, 07:13:43 pm »
Contact Fluke but it's probably a special mode for service centers. I think the only user power-on features for this series are disable continuity beeper, disable auto power off and screen segment test...You should be able to find those in your manual.
« Reply #11 on: May 12, 2017, 07:44:55 pm »
I emailed Fluke's repair service team late last night. So far they have not replied to me. I will let you know what they say.
Offline Fungus
« Reply #12 on: May 12, 2017, 08:36:48 pm »
"FCTY" is probably "Factory Reset" - restore all options to default.
« Reply #13 on: May 12, 2017, 11:13:42 pm »
Here is the response today from Fluke.
Typically when performing calibration tests and hooked up to the calibrator unit, you can hold the hold button and switch the unit to start the calibration process. It sounds like the meter is trying to start that procedure.
Sean Silvey | Product Specialist | FLUKE CORPORATION
email: sean.silvey@fluke.com | direct: 425.446.6992 |cell: 425.740.4294
Offline Everett_Tom
« Reply #14 on: December 16, 2024, 03:33:47 pm »
I saw a project somewhere that used this. In this mode, the Fluke 11x modulates the on-screen data out of the backlight, so with an IR received, you can decode serial data from the backlight. I heard it was so that the unit could be tested in the factory without connecting to a serial port.
