(1) Oddly enough Tektronix made the opposite error in the distant past. Their 2440 series of DSOs only have envelope detection listed as a feature but support peak detection as well.
(2) Automatic peak-to-peak triggering is another feature almost all DSOs lack but the last generation of analog oscilloscopes also lacked it.
On Japanese DSOs peak detect is typically called envelope mode so when it comes to envelope mode and peak detect you really need to read the manual to check what the oscilloscope manufacturer has implemented.
Quote(2) Automatic peak-to-peak triggering is another feature almost all DSOs lack but the last generation of analog oscilloscopes also lacked it.
I never heard of this mode until now. I had to look it up and it may be handy for repair work. It automatically triggers on the largest peak of the input signal.
A simple to use DSO Zoom is all you need, much more user friendly that the old dual delayed timebase on a CRO.
I actually find a dual delayed timebase to be easier to use because the horizontal controls scale with the timebase setting sort of like how when automatic peak-to-peak triggering is used, (2) the trigger level control scales with the waveform levels. It is easier to design a poor user interface for pan and zoom.
Pan and zoom is very useful but not always a replacement for delayed acquisition with a second timebase. The sample rate is limited by the main time/div and record length (3) no matter what the zoom is set to. This came up here a couple months ago here with a Rigol DS1000Z where a new user wanted to delay 1 second to capture the following pulse from the 1 PPS output of a GPS receiver and found that the sample rate was then too low to capture the edge accurately even with the Rigol's long record length.
Older and higher end modern DSOs have delayed acquisition and triggering as well as pan and zoom which can get confusing when both are used at the same time. More than once I have used automatic setup or restored the default state on the DSO I was using because that was faster than figuring out how to undo the combined pan, zoom, unlocked horizontal traces, and delayed sweep features. Or in the case of recent DSOs, combining delayed acquisition with pan and zoom caused them to crash.
(2) Automatic peak-to-peak triggering is another feature almost all DSOs lack but the last generation of analog oscilloscopes also lacked it. (4) Auto level is a poor substitute and is a major reason I often use an old analog oscilloscope or DSO which support automatic peak-to-peak triggering for rapid diagnostics.
(3) This is a good justification for large record lengths if dual timebase capability is not present and explains why dual timebase capability was common even in low end DSOs up until recently. Single timebases with pan and zoom replaced dual timebases in low end DSOs when large acquisition memories became inexpensive enough.
(4) Automatic level triggering is cheaper to implement than automatic peak-to-peak triggering if the trigger level is set digitally which explains why the last generation of analog oscilloscopes and almost all DSOs with an analog trigger lack automatic peak-to-peak triggering. Automatic peak-to-peak triggering should be free on DSOs which have digital triggering but inexplicably they lack it.
Naiively perhaps I would have thought I would get away with a large memory and properly selected sampling rate. In the PWM fan example, assuming PWM frequency is 400kHz, we might want to have at least 10 samples per period, hence I'd chose a sampling rate of 4MHz (or thereabout). If I have a memory depth of 12MS, a full buffer gives me 3s (well, 1.5s for two channels). This clearly doesn't work for all conceivable use cases, but should be more than enough to clearly see the fan's tacho output (a few dozen to a few hundred Hz), no?
No. Only with alternate triggering you can get the two signals stable on the screen.
Sure it's been a little while since I've had to use a CRO and I used the Dual timebase heaps BUT with the Siglent's I have I can't see a use case or any CRO feature you've listed unsurmountable with the UI in a SDS1kX.
The Zoom gives me 2 independent timebases that with one push of the timebase control lets me toggle between each, the holdoff and Horizontal position (pan) give me any delay I might need and I can pan in either timebase if needs be.
The Trigger level is common to the main and Zoom windows and in the case with Siglent's can be set to 50% of the waveform amplitude with a push of the Trigger level control.
No. Only with alternate triggering you can get the two signals stable on the screen.Well, single shot of course. Not sure what 'stable on screen' would mean for two unrelated signals or why I would want it.
Use the scope to inspect the waveforms to make sure they're clean and at the proper levels, then feed them into a dual channel counter. It will tell you all about the two signals in terms of frequency, duty cycle, etc.
No. Only with alternate triggering you can get the two signals stable on the screen.Well, single shot of course. Not sure what 'stable on screen' would mean for two unrelated signals or why I would want it.Poor choice of words on my side. I rather meant that 'stable on screen' for two unrelated signals would be actively misleading. There is after all only one timeline (ignoring relativistic effects here). Take your data, analyze it afterwards, see the relationship between the signals (or the lack thereof). I rather want my instruments to lie to me as little as possible.
I think the two different time bases were a (clever) crutch invented for analog oscilloscopes, which just couldn't store sufficient amount of data (not more than one screen). I don't think it has a place in the realm of digital scopes.
This is why I still like Tek 7844 real dual beam scope.
) channel scope is the best choice. Having digital channels is handy but you'll need to verify whether the signal levels / edges are correct first using an analog channel. I'd go for an MSO rather than an external logic analyser because you see the analog and digital signals in the same time domain using an MSO.
I'm looking for a first scope. First I thought getting Siglent sds1104x-e because of its possibilities for waveform and MSO with extra equipment. But would 2 channel scope + logic analyzer separate be better choice? In which case do I need 3-4 channels if I also get logic analyzer?
Do any (non-USB/PC) oscilloscopes come with HDMI and direct output to a 1080p (or greater) monitor? Having such large screen real-estate and being able to see so many channels sure would be a nice selling point!
The R&S RTO6 has a really big (15.6") capacitive touch screen and supports both HDMI 2.0 and Display Port+++
Simply when you want to see more than 2 channels...
Seriously, person is discussing sub 600 USD scopes.
Statement that R&S RTO6 is a good scope, in this context seems, I don't know, just a bit too enthusiastic, maybe?
Even saying that RTB2000 is good scope is not relevant in the price range discussed.
