Ok, I'm just looking averywhere on the web and here to try to find a goot DMM for my needs
I've already watched all Dave's and other members videos and now it's the time to ask if I am missing something
The most use I do of a multimeter if for low voltage applications... usually I repair whats broke up in my life: notebooks, smartphones, motherboards, audio/video equipment, etc... other times I build something I have in my mind
Sometime I need to repair switching PSUs and those times I reach my maximum voltage: about 400V rectified (those times I use an oscilloscope)
My actual equipment used in the last 20 years:
- a cheap "FUKE" chinese DMM, 1999 counts, manual range, bought in an electronic trade fair
- another cheap unbranded chinese rugged DMM, 1999 counts, manual range... I don't know why and when I bught it
- another small repaired DMM, found broken somewhere
- an old Philips dual track 50MHz oscilloscope
Both multimeters has only one standard 250V glass fuse, and I've never broken one.
Lately I started to build some embedded applications with Arduino and similar HW, and developing the firmware I found the need for an upgrade of my equipment... the last one is about 25 years old
So, what miss and I'm looking for needs to have:
- price under 200 €
- not less than 100 MHz logical frequency counter
- duty cycle
- PC connection (USB or BT)
- a good precision if preferred
- temperature is also preferred
- input protection is NOT needed... with both chinese cheap crap (and after inadvertently touching main) I'm still alive
EDIT: - AA or AAA batteries are preferred but an utopia
First option is to buy 2 DMM with different target:
- general use: UT139C (Tenma 72-7780)
- digital/log up to 220 MHz: UT61E (Tenma 72-10415, Gwinstek GDM-461) / Victor 86E / Owon B41T
Second option, an all-in-one a bit more expensive:
- up to 200 MHz: UT71B (Tenma 72-7730A)
- up to 400 MHz: UT71C (Voltcraft VC920) / UT71D (Tenma 72-7732A, Voltcraft VC960) / Voltcraft VC880
- up to 100 MHz: Extech Ex542 (CEM DT-9930)
The specified frequency ranges are real or only on paper? I've not found nobody testing more than 40 MHz
I've looked also to known better brands (such Brymen BM829s) but are limited to 1 or 2 MHz
Thank you in advance for your precious help and for this great blog
Moreno
