Author Topic: e4+ vs therm app vs thermal expert  (Read 3646 times)
Offline dazlerTopic starter
« on: May 13, 2016, 12:15:23 am »
Hi, I was looking at a camera at this price point.
I would use it mostly for home issues, to find insulation problems, holes on HVAC ducts, air leaks etc.
I have seen that the therm-app produces super images but not to clear on the flir e4+ (mod) compared directly to the therm-app or thermal expert.
any advice,
Thank you.
Offline Spike101
  • Country: at
Re: e4+ vs therm app vs thermal expert
« Reply #1 on: May 13, 2016, 05:32:18 am »
I don't have any experience with any of the devices you consider. But i had Flir One for a while now, and i find it pretty annoying having to attach it to the phone every time i want to check something. Most of the time, for quick checks I'm too lazy to find my phone and just use the IR gun instead..
So I for one would definitely go with the E4 instead of one of those phone attachments just as a matter of convenience..
Offline efahrenholz
« Reply #2 on: May 14, 2016, 09:55:06 am »
The modification of the E4 is a great option if you don't mind the difficulty level and the fact you have to hunt for a specific model that has an older firmware. Most the ones I see listed, the seller knows you want it for that reason and gouges the price.
As far as the other two, very good units. Personally I would go with the Thermal Expert because it's slightly cheaper of the three. It also fits right on the bottom of the phone, rather than being required to clamp on.
« Reply #3 on: May 14, 2016, 10:49:56 pm »
thanks,
I was looking into buying it already with the mod so is around 1,200 the therm-app is about 950 the I3 not sure.
I have not seen good side by side of the e4 mod vs the other two.
I wonder if I would regret getting the E4+ if the other two are that much more advance to see air leaks from the HVAC ductwork.
Thank you.
Offline iampm
  • Country: hk
« Reply #4 on: June 04, 2016, 11:21:19 am »
I tried both, and ThermApp's image is better than the MOD E4+. App has more pixels and the 19mm lens is larger than the E4's 6.7mm.
E4+ has more temperature measurement options and a report option.
If you only concern the image clarity, pick the APP.
Online Fraser
« Reply #5 on: June 04, 2016, 12:56:58 pm »
I own several thermal cameras and whilst I love the FLIR E4 ergonomics, it is a compromise solution in order to meet its BoM target.
The microbolometer is what could be described as a 'bare bones' economy version. Do not get me wrong, it's good, just not great. Then there is the lens. I am aware that a lens is sized to meet the needs of the microbolometer physical size, but bigger is still better. FLIR used a fixed focus, small aperture lens in the Ex series. This makes them very easy to use but that lens will never produce an image as good as a larger manual focussed lens. Looking at images produced by the Exx series gives an idea of what I am saying.
The relatively new phone mounted cameras are undoubtedly very capable, using decent microbolometers and lenses. My only issue with them from a personal perspective is that they need a phone host. I prefer the more ergonomic 'all in one' thermal cameras for daily use.
Fraser
« Last Edit: June 04, 2016, 12:59:27 pm by Fraser »
