Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Thermal Imaging
Flir A320
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Flir A320 (Read 1291 times)
ir.ukrm
Contributor
Country:
Flir A320
on:
August 06, 2019, 11:11:52 am »
Flir A320. Is this detector a temperature sensor?
Logged
Ismsanmar
Contributor
Country:
Re: Flir A320
Reply #1 on:
August 06, 2019, 01:42:58 pm »
Are you talking about the item with the sticker attached? If you were a little more explicit ...
Logged
ir.ukrm
Contributor
Country:
Re: Flir A320
Reply #2 on:
August 06, 2019, 01:51:02 pm »
Yes, this is a part with a sticker.
Logged
Ismsanmar
Contributor
Country:
Re: Flir A320
Reply #3 on:
August 06, 2019, 01:57:21 pm »
That's the mini servomotor that controls the focus, in manual or auto, moving the internal germanium lens of the optic assembly. If you remove the remaining 5 torx screws to release the sensor assembly, you can see it.
Last Edit: August 06, 2019, 01:59:47 pm by Ismsanmar
Logged
ir.ukrm
Contributor
Country:
Re: Flir A320
Reply #4 on:
August 06, 2019, 02:06:42 pm »
And then what kind of engines are these?
Logged
Ismsanmar
Contributor
Country:
Re: Flir A320
Reply #5 on:
August 06, 2019, 02:45:34 pm »
Both are relays. One controls the FFC, and the other one is the automatic shutter, that's like the FFC but with a hole on the center.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Thermal Imaging
Flir A320
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
