Poll
274 (27.9%)
444 (45.3%)
49 (5%)
50 (5.1%)
164 (16.7%)
Total Members Voted: 803
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 3802485 times)
Online Bud
« Reply #6450 on: January 10, 2015, 05:15:26 pm »
some strings are confusing:
ID_SETUP_SAVE_IMAGE_RESOLUTION_SUPER_BRIEF IMAGE_RESOLUTION_SUPER
ID_SETUP_SAVE_IMAGE_RESOLUTION_NORMAL_BRIEF IMAGE_RESOLUTION_NORMAL
but .ui.userSettings.saveImageResolution is integer and default it is 0
What is this?
That seems to be another menu for setting up save image resolution but heck knows what that means.
Here is a screenshot
Offline janekivi
  • Country: ee
« Reply #6451 on: January 10, 2015, 05:23:12 pm »
You remember my last video preview... actually, all this is working in realtime too.
And there is alarm with sound - there was place on board for buzzer?
Now I wondering here, you had all this and more easily available all the time
and nobody wasn't turn them on? They didn't talk to everyone?
(in nonencrypted machines)
But now I'm in trouble and must say goodbye to my hideGraphics
in Nomeasure preset because measure option is using this and after "Clear"
all is clear... and nothing you add there comes visible after that.
« Last Edit: January 11, 2015, 08:29:45 am by janekivi »
Online Bud
« Reply #6452 on: January 10, 2015, 05:45:56 pm »
HideGraphics is not a big loss.
Offline FredB
« Reply #6453 on: January 10, 2015, 07:23:01 pm »
More measurements is better than less or nomeasurement.... :)
Offline gemrough
« Reply #6454 on: January 11, 2015, 05:51:10 am »
thanks janekivi for your hard work. New menu is working like a charm.
Offline janekivi
  • Country: ee
« Reply #6455 on: January 11, 2015, 08:58:20 am »
Good but all my things is not working like I want...
Something I can do. For example all spots and boxes not movable always
but they can be deleted and you can add new and move this. And to settings
menu I can't add things I want. For example MSX focus value in
resource=".image.fusion.userDistance" is changeable
but how I can change .ui.userSettings.hideGraphics
to false or true?
http://wikisend.com/download/605102/2015_B_0.3.avi
Online Bud
« Reply #6456 on: January 11, 2015, 10:31:45 am »
You may be stretching the camera beyond its capabilities
Offline janekivi
  • Country: ee
« Reply #6457 on: January 11, 2015, 12:07:51 pm »
Ok! Thanks for hint.
I found from T6xx software some needed stuff to add.
This is expanding my playground.
Give more hints and do your own experiments too.  :-+
It have .caps.config.image.services.store.superResolution.enabled
for IMAGE_RESOLUTION_ULTRAMAX :(
(But I stole from it "TimeLapse". Saves images after time you set, min 15 sec.
And I can rotate stuff on screen now. Don't tell to anybody)
Yeah... and what you think, how big in T6XX all icons and other stuff is... logo is half of screen
Where I get igons I need or how to resize?
« Last Edit: January 11, 2015, 07:59:00 pm by janekivi »
Offline FredB
« Reply #6458 on: January 11, 2015, 08:42:53 pm »
In post #888 and #910 are some files to download that are decrypted for use with earlier firmware. In this files are also icons.
Online Bud
« Reply #6459 on: January 12, 2015, 04:43:27 am »
:-DD
Offline Garball
« Reply #6460 on: January 12, 2015, 04:59:00 am »
So I've read about 20 pages of the blog and it's really hard to know what to do because instructions are spread over 430 pages. I want to buy a new E4 but it would be great if there was a sticky for the latest up to date instructions (unless I'm missing something). I'm technically ok with UNIX and have a Windows 7 laptop somewhere.
Thanks.
Offline mamalala
« Reply #6461 on: January 12, 2015, 05:27:20 am »
:-DD
I'm wondering if it would be possible to simply add a touchscreen overlay to the display? I mean, does the processor have the pins for that exposed or on a (unpopulated) connector somewhere?
Greetings,
Chris
Online Bud
« Reply #6462 on: January 12, 2015, 06:35:30 am »
May possibly have a switch in the software somewhere to allow using E4 hard keys. Will keep looking
 8)
Online Bud
« Reply #6463 on: January 12, 2015, 06:51:00 am »
Thanks.
Be realistic, nobody will sit and dig through 400 pages to write instructions for you and then keep them current , since you want "the latest up to date". How do you expect one to do this.
But i will make it easier for you- all necessary information for a new e4 is in the last 50 pages. I did not read the whole thread either.
Offline janekivi
  • Country: ee
« Reply #6464 on: January 12, 2015, 02:37:11 pm »
There was table and I can select data to table and save but... touch
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg582236/#msg582236
Now I disabled it and have there "Sketch". Pen is useless but I can add markers.
For recording I found "TimeLapse" and "Screening".
For Measuretools I found 2 "User Presets" - you can make them and save.
Advanced measuretools - Line have "Center and Rotate"
Alrms can be set.
About HideGraphics - clear screen - they have programmable button on some cameras
and this function can be set to it.
What I found out, there some things needs enabling in many places and many things.
With that video recording - I need help. I can't figure out that easily what I must enable
and set in resource. I need [rls -rl > \FlashIFS\allsettings-yourcameratype.txt] from
camera which have video, from EXX is good.
« Last Edit: January 12, 2015, 02:56:30 pm by janekivi »
Offline janekivi
  • Country: ee
« Reply #6465 on: January 12, 2015, 05:19:32 pm »
So, buying instructions...
There was info where is the cheapest deals but actually this is "Flir E4 Thermal imaging camera teardown" and we taking 2.3.0 software apart right now.
Offline gemrough
« Reply #6466 on: January 12, 2015, 05:40:23 pm »
Here is instructions for resolution hack for 2.3.0. I am re posting this with a few edits to the original:
(originally posted by compet17)
STEP BY STEP INSTRUCTIONS for Flir E4 (Firmware 2.3.0) for beginners (How I did it... and it worked)
(If somebody finds an error in this procedure, please tell me immediately and I will correct it)
- Get FlirTools from Flir website (free download) PC version recommended (Note: V5 does not work on Win XP...)
Get 4.1 here:http://cdn.cloud.flir.se/update/flir tools/4.1.14066.1001/flir tools.zip
- Install FlirTools on your PC
- Get the files "Set_RNDIS_temporary.fif" and "Set_RNDIS_permanent.fif" from this forum here.
- If you want to use the "permanent" file, you also need "remove_RNDIS_Permanent.fif"
   (Temporary.fif sets the USB of your cam to RNDIS mode UNTIL A REBOOT. Permanent does the same but it stays in RNDIS until YOU RUN
     REMOVE.fif)
- Get E4 hack "v04.zip" for Version 2.3.0 here.
- I assume that the installation of FlirTools does also install the camera driver. If not install it manually. Links are found in this thread
- Get PYTHON version 2.x (not version 3.x!) from the Python website and install it. This is needed to run the hack script. It's a programming language.
- Connect your E4 via USB to your PC and turn it on
- Go to "Programs(x86)/Flir systems/Flir Tools/bin and execute FLIRInstallNet.exe (this is part of the FlirTools software installed in step 2)
- Select the Set_RNDIS_xxxxxxx.fif (permanent or temporary) and click RUN FIF button.
  (A timeout error is normal after the command has succeeded because USB is now set to RNDIS mode)
(On mine I had to disconnect and hard reboot for the change to show up.... which meant I had to use the permanent file.  I had to use a win 8 PC.  After the Hard reboot I moved to a win XP PC)
- Wait a moment and open a CMD window, then enter IPCONFIG
- An additional network connection should be listed with IP Address 192.168.0.1 and gateway 192.168.0.2
- Enter "FTP", then "open 192.168.0.2" and a connection to your cam should be established
- Login with user "flir" and password "3vlig"
- Issue a "dir" command and the files and directories of your cam are listed.
- If all that works, type "quit" to exit and close ftp connection.
- copy the hack files from the v04.zip into the PYTHON folder.
- open CMD, use the command cd and go into python folder and enter "python apply.py apply 192.168.0.2"
- it will read two files from your cam and stores them in a backup folder, then it will do some magic with the files.
- you will find newly created conf.cfc and common_dll.dll in that folder and upload them back to the camera.
- In case you get an error 500 at the upload, you have to upload the files manually by FTP:
*** Only in case of error 500 ***
- Open CMD and FTP again and connect to your camera as before
- go to the indicated folders (cd /foldername/foldername/foldername)
- check the folder with "pwd" to make sure you're in the right one
- Use the lcd command to change to your local directory where the conf and common files are.
- put the files to the correct folders (put filename)
MAKE SURE YOU PUT THE RIGHT FILES INTO THE RIGHT FOLDER!!!
- Reboot your cam by removing/inserting the battery
- Be happy!!!
- It is possible that the measuring spot is off center after reboot. Turn the spot off/on in the setup menu of the cam and it should be centered.
« Last Edit: January 29, 2015, 07:56:23 pm by gemrough »
Online Bud
« Reply #6467 on: January 12, 2015, 06:06:28 pm »
gemrough,
Now expect them saying my zoom/pip/scale/whatever not working please help
Offline gemrough
« Reply #6468 on: January 12, 2015, 06:23:51 pm »
gemrough,
LOL I know....
Online Bud
« Reply #6469 on: January 12, 2015, 07:42:46 pm »
...that is why a new person should go 50 pages back and read.
And it is not hard to do, two months ago i had no idea about the camera. By now i learned how to navigate through the file structure, learned some QML, had good start using information others posted, and now can try different  tweaks by myself.
Offline Garball
« Reply #6470 on: January 13, 2015, 01:53:14 am »
Thank you Gemrough, I'm know this will help countless others too.  It would be great if the moderator could stick this into a sticky at the beginning if the post so it doesn't get lost.
And Bud, I'm a new poster here and appreciate your feedback. However, the great thing about organizing this information is that it's more likely to get used by others, including myself. Frankly I don't have time to read thru hundreds of posts and aggregate bits and pieces of instruction that may or may not work.
I'm buying my E4 from shop fluke.ca for $995 CAN. I suspect e price will go up 18% due to the Canadian dollar crash. Great deal if your buying in US dollars though.
Offline copineau
« Reply #6471 on: January 13, 2015, 02:55:35 am »
965$ at amazon.ca + free shipping. All in canadian $
Online Bud
« Reply #6472 on: January 13, 2015, 03:05:25 am »
Then you wont get your unit loaded with _all_ of the updates.
Offline OrBy
« Reply #6473 on: January 13, 2015, 06:35:48 am »
I really suggest doing some reading. The work that so many people have put into this thread is nothing short of amazing and really wont get the full use out of the unit unless you do.
Online Bud
« Reply #6474 on: January 13, 2015, 08:27:51 am »
Great picture, OrBy  :-+
