Author Topic: Flir One Thermal imaging camera teardown and hacks  (Read 116325 times)
Offline frenky
  • Country: si
    • Frenki.net
Re: Flir One Thermal imaging camera teardown and hacks
« Reply #100 on: March 10, 2016, 11:18:16 am »
I was thinking to replace original lens (for the Seek) with this one:
http://www.aliexpress.com/store/group/GaAs-Focusing-Lens/1513187_259497074.html
But I'm not sure what is original focal length of lens in F1 or Seek...
Offline Bill W
    • Fire TICS
« Reply #101 on: March 11, 2016, 12:23:24 am »
That lens is a 20mm diameter 50mm focal length, so F/2.5 assuming the A/R coatings are over the whole 8-14um band and not just for the laser wavelength
A flir1 is 46° on a 160 pixel at 17um.... so lens is around 3mm focal length
Seek is 20° on a 206 pixel at 17um.... so 10mm focal length
A 50mm FL lens will therefore be a lot narrower field of view but also a bit less sensitive (x2 or so).  Forget temperature readings.
Flir1 comes out at 3° for instance.
Bill
www.fire-tics.co.uk
Offline Ben321
« Reply #102 on: March 31, 2016, 01:58:28 pm »
I now have the flir 1.0.9 firmware update pkg.
Lets see what that contains  :-DD
now i just need to find a way to depkg the file
Is 1.0.9 an official update made by FLIR? If so, where on their website can I download it?
Offline tomas123Topic starter
« Reply #103 on: March 31, 2016, 11:51:25 pm »
it's for Flir One Gen 1 for Iphone
Offline Ben321
« Reply #104 on: April 01, 2016, 01:34:30 am »
I heard that there was some way to make the FLIR One allow charging of the phone through it, so after the FLIR One got done charging, it would charge the phone. Is there a way to do this with FLIR One for Android with just firmware hack? Or would it require a hardware mod as well?
« Reply #105 on: April 01, 2016, 07:59:51 am »
Yes, after a FW update the F1G1 charged the Iphone after full charging his own batterry.
But the Iphone has not a USB connector.
We know. that the Android Phone work with a plugged in F1G2 as USB host.
And you can't load a USB host by following the USB specification.
But some USB host controllers in Android phones ignores the specification.
Therefore it's sometimes possible with this steps:
- use a non specification Y-USB-cable
- load the phone over USB (USB controller goes in slave mode) over the first cable
- now plug in the F1G2 in the second cable
- the USB controller goes in host mode, but the charge controller is furthermore connected to the 5V-USB power
this is completely outside the USB specification
Offline Uho
  • Country: ua
« Reply #106 on: June 22, 2016, 03:52:37 pm »
another question is: has anyone stick a better lens in front of the sensor to get much better results? :D
I tried to change the optics . An example can be found here. In T-10 using the Lepton sensor. https://youtu.be/gUOvAg0dGxY
Or additional optics.
« Last Edit: June 22, 2016, 03:55:08 pm by Uho »
The following users thanked this post: RO
Offline Uho
  • Country: ua
« Reply #107 on: June 22, 2016, 03:58:03 pm »
View from the additional optics
Offline Uho
  • Country: ua
« Reply #108 on: June 24, 2016, 08:11:33 pm »
Flir One V2. Telephoto and macro lenses. Using
https://youtu.be/OzZFwJr9vQw
Offline allstone
  • Country: lt
« Reply #109 on: October 03, 2016, 12:39:53 pm »
Hm, does not it imposes and shares 5V-USB power from phone to Flir One? I mean it can hurt the camera if its blocking 5V deliberately when connected directly.
