Author Topic: Flir scout tk lcd replacement  (Read 490 times)
Offline thechainringTopic starter
« on: June 20, 2026, 02:15:04 pm »
so found a scout tk a couple years ago that had been run over with a car and the lcd was damaged I was able to verify that it did still work.  the lcd and ribbon cable was thrown away by mistake and this has been sitting in a drawer for a couple years.  is there any way to hook it up to a tv or pc.  I have not been able to get it to connect to my laptop but i think its an issue with my laptop drivers. Or is there a lcd that i can but and 3d print the case to put this back together2845086-0
Offline Fraser
Re: Flir scout tk lcd replacement
« Reply #1 on: June 20, 2026, 02:44:15 pm »
If you find an LCD driver IC on the PCB that is made by KOPIN, you will need to look up the data sheet for that IC and find  the KOPIN LCD module that matches it. They are not easy to source.
https://www.kopin.com/technologies-products/custom-solutions/microdisplays/
Fraser
Offline Fraser
« Reply #2 on: June 20, 2026, 02:49:10 pm »
KOPiN A220/221 driver IC data sheet in case it is of use.
https://datasheet.datasheetarchive.com/originals/library/Datasheets-SW3/DSASW0041288.pdf
Fraser
Offline Fraser
« Reply #3 on: June 20, 2026, 02:52:29 pm »
Offline Fraser
« Reply #4 on: June 20, 2026, 02:56:00 pm »
This thread may also be is some interest. It relates to a different model of FLIR SCOUT but the units may share the same, or similar LCD panels.
https://www.eevblog.com/forum/thermal-imaging/flir-ms-ps-ls-thermal-scope-teardown-by-fraser/
Fraser
« Last Edit: June 20, 2026, 03:05:28 pm by Fraser »
« Reply #5 on: June 22, 2026, 10:09:17 pm »
do i have to use that specific lcd or is there any other options like using usb c while it plugged into my laptop or usb a to hdmi and plug it to the tv.  or a different lcd it doesnt matter the size so much as long as i can get it to work.
« Reply #6 on: June 22, 2026, 10:11:01 pm »
or is a driver ic what the screen is called
« Reply #7 on: June 24, 2026, 10:10:04 am »
so the ic on my board is the kopin kcd-a912-bb and now i just have to find a lcd that is compatible with that ic or did i misunderstand something.  do you know what lcds are compatible and where to get one.  i requested info from kopin.
