Ask FLIR for a quote on sensor cleaning. You might be surprised. Then again FLIR might well charge a lot as it might include a camera test etc. No harm in asking.
From my perspective you need to consider the physics of the situation. The window can be scratched quite easily if a dust particle gets trapped between the window and the cloth. It just acts like sand paper. Will a mild fine scratch matter ? In my experience it will not effect imagery even at 640 x 480 as it is outside the focus point and so fine. The idea behind cleaning a sensor using the ‘drag clean’ soft cotton wool and IPA method is to very gently dissolve and capture contaminants without apply pressure to the sensor window, so avoiding scratches. The cotton is swept across once and discarded. The process is repeated until all contaminants have been removed. A totally clean sensor window can actually be gently ‘polished’ with a lens grade micro fibre cloth but you need to be certain the window is clean first. I use an inspection microscope.
Q Tips soaked in IPA are useable but only at the edges where dirt collects after drag cleaning. They are too hard and apply too much pressure if high levels of contamination are present. Remember, it is important to not press a sharp spec of dust into the windows surface as that is how the scratches form.
In a perfect world the sensor would be removed and its window washed under running cleaning solution to literally lift and wash away the contaminants. Such a process is expensive. Alternatives are special optical foam cleaners that use carefully selected chemicals to loosen the contaminants and the foaming action to lift them away from the surface for gentle removal with an absorbent material. Foam cleansing of optics has been around for many years and applies no real pressure to the surface being cleaned. This has now extended to cleaning cars paintwork ! The use of specialist foaming cleaners for cars has been around in industry for years but now the public have taken to the idea as well.
So in short, if you want the job done to a high standard by those who know best and do such cleaning all the time, send the camera to FLIR. The alternative is very careful use of soft cotton wool and IPA. Acetone is also used but I use IPA. I do not recommend any form of chamois pad or dense cleaning cloth, both can trap dust and cause scratches.
At the end of the day, it is your camera, your money and your risk
If you already send a SLR in for cleaning, why not at least enquire of FLIR. I would be more wary of cleaning an SLR though.... lots of risks involved there ! I estimate a fee of £250 from FLIR for such a task.
Another thing to consider is what the contamination actually is and is it ‘sticky’. Some contaminants can be very challenging to remove without applying pressure !
Fraser
