G'day.
I bought a defective MSA Evolution 5200 from Ebay. Description said, image stays gray most of the times.
Had this issue before with a IIG thermal imager, freed the shutter and it just worked fine.
I tested the MSA, and whenever I switch it on, the shutter seems to be stuck, when I hit the unit, image comes up. Sometimes the shutter "wants" to close, and freezes the given image, so there is a "ghost image", hope you know what I mean...
I disassambled the MSA today, but can't find a way to the shutter. A label on the side of the unit says "Indigo Core", I found some info on the indigo cores, but I am pretty sure, disassembly to the shutter motor is very delicate...
Maybe some of you have a good idea?
Best regards
Henning
