Author Topic: Infiray and their P2 Pro - discussion  (Read 108655 times)
Offline IwuzBornanerd
Re: Infiray and their P2 Pro - discussion
« Reply #175 on: November 25, 2022, 06:16:07 am »
« Last Edit: November 25, 2022, 06:33:02 am by IwuzBornanerd »
I am not opposed to exercise, unless it is an exercise in futility.
Offline Fluvance
« Reply #176 on: November 26, 2022, 01:14:28 am »
Tomasis,
I have the Tiny1-c Windows SDK with the driver files if that is of interest to you for Topdon software modifications.
Fraser
Any chance it would be possible to get that SDK? Or a link where to find it? I just bought the Mileseey TR160i 160x120 camera with, presumably, the same Infiray sensor configured to a lower resolution. I'm hoping to get it working on my computer but no luck so far.
Interestingly, this Mileseey camera doesn't work with any other Android thermal app intended for Tiny1-c sensors. I read some people were able to use the P2 Pro with apps from other brands, so I was expecting the same to apply to this sensor. I can however use some apps intended for generic endoscope cameras. It shows the splitscreen input directly from the camera, a 160x120 black and white feed showing the thermal image, and a second 160x120 greenscale image showing what I expect is the raw temperature information in each pixel.
Offline chemary
    • CheMaRy Web Page
« Reply #177 on: November 26, 2022, 10:33:51 am »
I have Victor 328B that is exactly the same that Mileseey (but the 256x192 pixels version) and when you connect with a generic camera app you see a 256x192 stream and a second image on top that maybe is the temperature information as you said or the extra pixels as I think Tiny1 gives more than 8 bits. I suppose the 160x128 camera has a different USB descriptor and that's why it can't be used with other apps, but have you tried the UNI-T app, it lets you choose the 256 or 160 version when the app is launched.
Probably unlocking the higher resolution would need a firmware update as the camera only presents 160x128  resolution.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #178 on: November 26, 2022, 02:59:32 pm »
I need to look into Windows drivers etc but certainly not 'Plug & Play' on a windows PC at the moment.
I just plugged the P2Pro into my Win7 PC and after short delay it seems to work fine as a webcam.
I've also had it running on a raspberry Pi, using MotionEye, configuring as a standard USB camera, so should work with any RasPi software that can talk to a USB camera ( and is happy with the slighly oddball 256x192 resolution)
« Last Edit: November 26, 2022, 04:57:26 pm by mikeselectricstuff »
Day Job: Mostly LEDs
The following users thanked this post: Fraser, arvidb
« Reply #179 on: November 27, 2022, 10:38:29 pm »
Review & teardown :
https://youtu.be/YMQeXq1ujn0
The following users thanked this post: Fraser, deephaven, bitwelder, chemary
Online FraserTopic starter
« Reply #180 on: November 27, 2022, 11:24:39 pm »
Nice review Mike  :-+
I agree that this diminutive camera is great to have available in the lab. I have been using mine for a similar period of time as you and I must say I really like it. It is products like this that will really pose a threat to FLIR and Seek Thermal dongle type thermal cameras. I was pleasantly surprised by my units image quality and frame rate and thank you for testing the frame rate as that has saved me a job  :-+
My Dianyang CA10 produces a very nice thermal image and that uses the larger Infiray S0 core that is very similar in size and appearance to a Seek Thermal Mosaic core. The S0 offers a larger lens and manual focus and it is to be found in the Infiray T2 series of camera dongles. For me, I would like to own both the P2 and a T2 as they are both strong performers and the fixed focus suits some applications but manual focus provides excellent sharp imaging in other scenarios. I discovered this when comparing my FLIR E4 with my E40….. the manual focus needs of the E40, with associated shallow depth of field, could actually be a bit annoying when imaging targets at differing distances. The fixed focus E4 just provided an acceptable image anywhere in its range of fixed focus, and it has a decent close focus specification. Your video review shows just how easily the P2 may be used for PCB analysis and its close focus without the Macro lens is impressive  :-+
Like you I have been using my P2 instead of some of my larger cameras as it is just so convenient. I have lots of thermal cameras to choose from yet I used to grab my E40 (E60) or Hikvision DS-2TP31….. I now reach for the little P2 Pro if needing to do a quick thermal check. For PCB analysis I still use the Infiray S0 cored DYT CA10 (upgraded to CA20 spec) as that offers more capable software that runs on a PC.
Fraser
« Last Edit: November 27, 2022, 11:48:19 pm by Fraser »
The following users thanked this post: Squiffy
Offline scottc19
« Reply #181 on: November 28, 2022, 01:39:28 am »
Are the P2 and P2 Pro identical aside from the temperature range?  Or is there another difference I missed?
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« Reply #182 on: November 28, 2022, 09:21:53 am »
I have my P2 Pro running on a Samsung A8 but having a problem. If I use the Xtherm infrared app it works fine. But, if I try to use the P2Pro app, it is asking to turn on the OTG function, strange if it works with the other app.
I've tried various Default USB configurations in the developer settings but none seem to make it work.
The phone is locked to a particular mobile phone company, would that be an issue?
Offline chemary
    • CheMaRy Web Page
« Reply #183 on: November 28, 2022, 09:36:33 am »
It happens some times to me, try to kill any other open app, disconnect the camera, then open P2 Pro app and when it says "Please plug in the device and turn on the OTG function" connect the camera, be sure to cancel any dialog saying if you want to open other app. If you accepted to always open an other app when you connect the camera, you have to go to Android settings remove it.
Offline deephaven
    • Deephaven Ltd
« Reply #184 on: November 28, 2022, 10:14:50 am »
Thanks for the reply. I tried your ideas but nothing seems to stop the app requesting OTG be turned on.
Offline sofakng
« Reply #185 on: December 05, 2022, 01:35:22 am »
Hey guys... what's the difference between these different models?
I've ordered the TOPDON TC001 a few days ago ($175.95 shipped) after doing some research but I couldn't find too much information about it.  I can't imagine anything better in the price range and it seems like the Infiray P2 Pro uses the same chip?
Offline Fluvance
« Reply #186 on: December 05, 2022, 07:37:58 am »
Something that I found interesting was that the Topdon TC001 Android application has a firmware update function. When I plug in my Mileseey TR160i 160x120 camera, the Topdon app suggests a firmware update for it. I'm hesitant to try it as I don't want to brick my camera from being used with the original app and possibly any app at all. But... The TC001 is a 256x192 camera, so there's a slim chance that depending on what the firmware is for, it could hack my 160x120 camera, which uses the same Tiny1 sensor, to a 256x192 camera.
Anyone have any theories on that? I suppose it depends how the Tiny1 is being configured to run in a lower resolution and if the controller/USB interface chip is the same between brands.
Offline chemary
    • CheMaRy Web Page
« Reply #187 on: December 05, 2022, 08:10:51 pm »
As I commented earlier I have Victor 328B that is the same that Mileseey TR256i and when I connected to Topdon Android app it asked to update the firmware, I didn't do it because it was working fine and I didn't want to brick the device, but after trying some apps I suspect some of them automatically updated the firmware because now it says I have the latest version.
I decompiled the Topdon Android application and inside there are 2 files named `P2-256-V3.02-20220310.bin` and `P2-256-V3.03-20220402.bin` as you can see in the attached pictures the date and version correspond to the firmware that I have, so all points that they are the firmware files.There are no firmware for the 160 pixels version so maybe you are lucky and they can upgrade the camera to the 256 pixels version, in theory the hardware is the same.
Having said that if you update is your responsibility, it may work or it may not work or it may even brick your device, my recommendation is that if it works fine for you and you value it stay with the 160 pixels firmware, is better that that bricking it.
Offline Gareth79
« Reply #188 on: December 06, 2022, 04:22:06 pm »
Finally got my P2 Pro ordered in the 11.11 sale. First impressions (using the Topdon app, which was the first that immediately worked) are that it's an impressive bit of kit. If they had a reliable/reputable resellers around the world, some side-by-side comparisons and some decent software then it should blow the western competition out of the water (or at least get some price reductions). They should get onto that rather than wasting time spamming enthusiast forums and selling direct on AliExpress, the product will sell itself.
edit: To add, I bought from the UNI-T store and received one with the silver case and a screen-printed white logo, not the style with the inset logo on a decal.
« Last Edit: December 06, 2022, 11:21:23 pm by Gareth79 »
« Reply #189 on: December 10, 2022, 11:58:50 pm »
A little update from me….
Like Mike, I have been testing the P2 Pro for a few weeks now and I am about to release the review that I have written.
Infiray released a new version of the APP on the 6th December and I loaded it today to see if some bugs had been fixed since my testing was completed.
To note: My September release of P2 Pro (1.0.5.220921) had some bugs that included …..
1. The APP sometimes not seeing the camera dongle and asking for it to be connected. The solution to this was to close down the P2 Pro completely and erase it from the APP history page in Android (three horizontal bar icon on desktop). The P2 Pro APP would then work correctly if manually started or the camera plugged in to initiate an auto run of the APP. I had this issue with the Samsung A6, A8 and S9 Plus phones.
2. On the Samsung S9 Plus, when switching to the Wide range (High temperature) mode, the displayed spot temperatures were all over 800 Celsius even when viewing a 20C target. No solution was discovered during testing. The A8 phone did not suffer from this issue.
The new release of the P2 Pro APP dated 6 December 2022 has fixed the temperature measurement error in the high temperature range on the Samsung S9 Plus. Sadly a new issue has appeared though. When selecting the P2 Pro APP icon the phone reports that the APP is not installed. Plugging the camera dongle into the phone initiates the starting of the P2 Pro APP and all works normally. Trying to start the APP with the camera plugged in still returns the "APP not found" error. Hopefully a fix will be released soon. This fault is present on my Samsung A6, A8, S9 and also my Motorola G5 so it is not a “Samsung issue”.
I have yet to test the new release properly but it still appears to have the issue of not always seeing the camera dongle and needing the history entry to be deleted before it will work again.
Fraser
« Last Edit: December 13, 2022, 07:56:49 pm by Fraser »
« Reply #190 on: December 13, 2022, 07:53:53 pm »
The P2 Pro review is complete  :)
https://www.eevblog.com/forum/thermal-imaging/review-infiray-p2-pro-thermal-camera-dongle-for-android-mobile-phones/
I intend to add to it over time but this is the core documents set.
Fraser
« Reply #191 on: December 13, 2022, 10:40:40 pm »
They're sending me a T2S to look at - as far as I can tell trom the website, it's basically the same as the P2 but with an adjustable lens, which should be more convenient.
« Reply #192 on: December 14, 2022, 01:06:52 am »
Mike,
The T2S will contain the Infiray S0 core that is also used in my DYT CA-10 Thermal PCB Analyzer  :-+
https://www.infiray.com/products/s0-series-long-wave-infrared-sensor-module.html
My CA-10 review with lots of pictures…..
https://www.eevblog.com/forum/thermal-imaging/review-dianyang-technology-ca10-circuit-board-thermal-analyzer-repair-rd/
It is a bit like Infiray’s answer to the Seek Thermal Mosaic.
Fraser
« Last Edit: December 14, 2022, 01:21:47 am by Fraser »
« Reply #193 on: December 16, 2022, 01:00:08 am »
A new P2 Pro APP version dated 14 December 2022 has been released on the play store. It addresses the issue of the APP icon failing to start the APP and makes recognition of the camera being connected more reliable.
Fraser
Offline cmpxchg
« Reply #194 on: December 19, 2022, 10:29:08 pm »
Has anyone had issues with the thermal image just hanging? I'm getting rather frustrated with this device - it seems extremely picky about which devices it will run on at all, it doesn't work on my Motorola smartphone, I tried a Xiaomi from a friend and it wouldn't run either (just stuck at the OTG screen). I've now got a Samsung tablet and it shows an image for a second or two, then just hangs (until restarting the app, at which point it shows a picture again for a second).
Connecting it to a Windows computer it works just fine (with the occasional stutter in the framerate, however), but that's not exactly how I imagined using this.
Offline tjhowse
« Reply #195 on: December 22, 2022, 01:37:44 pm »
I've found pretty severe JPEG compression artifacts affect the images captured from the P2 Pro using the "P2 Pro" app from the google play store. Does anyone have a recommendation for alternative android-based software, or a setting I've missed in the "P2 Pro" app? I'd get better image quality if I took a screenshot via the OS, as compared to using the built-in image capture. Toggling the "Improve image quality" setting doesn't appear to affect anything.
The resolution is fine, the images come out at around 350kB, 1440x1080x24, but the image quality is pretty ragged. It's especially obvious around the overlay text, there is a fuzziness about it that has nothing to do with the comparatively low-res thermal sensor.
« Reply #196 on: December 22, 2022, 07:19:01 pm »
tjhowse,
I agree, the images that are saved do not do justice to those seen on the phones display as a live image. Sadly the are no options for the user to change compressions levels in the P2 Pro App. The image quality control acts on the algorithm that is in the image processing algorithm and not the image save process. I saw little difference between the image quality enhancement being on or off.
There are other APP that work with the P2 Pro as, thankfully, the Tiny1 core is used in several other cameras.If the Vid and PId are the same, the other manufacturers software will often work with ten P2 Pro and even supports the high temperature range.
Take a look at the TOPDON TC001. It has Android and Windows software that may be downloaded from the TOPDON web site. Sadly the Uni-T UTi720M app will not recognise my P2 Pro which is a pity. Infiray have another Android App called “Go” that was for the P2 standard model but it still has the Pro option switch. I suspect saved image compression will be the same however.
It would be good to identify sources of alternative Apps for the P2 Pro so that the best ones may be used for a particular application.
Fraser
Offline tjhowse
« Reply #197 on: December 23, 2022, 04:46:45 am »
Fraser,
Thanks for the wisdom. Shortly after posting I found Chemary's post here: https://www.eevblog.com/forum/thermal-imaging/infiray-p2-application/ that lists a few other options too. I've since boxed the camera back up, since it was nominally a christmas present. <_<
I'll look at alternative softwares on christmas morning and report my findings.
Cheers,
Travis.
Offline oliv3r
    • Rigol related stuff!
« Reply #198 on: December 28, 2022, 09:20:19 am »
Hey all,
Without trying to derail this thread too much ;) I am curious why there's no mention of the T3 smartphone modules? They have better specs (focal distance might be different? But yes, cost a little bit more. Are they so new that this hasn't come up yet? Or they a bit older already?
Speaking of T3/T2, I suppose the biggest differences between the T and the P series is the target market? T for 'outdoorsy things' and P for professional use? Idk. I see that the T's are sold in kit form with one of those 'gun-type' holders, though on ali express that doesn't seem to be the case?
So am I missing something obvious, or is this discussion entirely price driven? Or do we wait for a P3pro :p
P.S. just noticed that on AE they also now list an iOS version, for those that care :)
Offline katzenhai2
« Reply #199 on: December 28, 2022, 07:07:05 pm »
Speaking of T3/T2, I suppose the biggest differences between the T and the P series is the target market? T for 'outdoorsy things' and P for professional use? Idk. I see that the T's are sold in kit form with one of those 'gun-type' holders, though on ali express that doesn't seem to be the case?[...]
T3 is marketed since 2019, so yes its a bit older (see older threads here by using the search function).
There are outdoor versions of the "T" devices but I think that depends on the used lens.
