Author Topic: Looking for a long range android thermal camera  (Read 3849 times)
Offline michaelnydenTopic starter
« on: September 28, 2024, 04:13:54 pm »
As the title says I’m looking for a long range thermal camera that can be used on android phone for mount to drone, I’ve played with a few and realized that a small fov is best for this goal as it focuses the resolution of the sensor over a smaller landscape and since it will be on a drone at distance, the small fov doesn’t matter it will still see a lot at 800m for example from the scene being observed.  Any recommendations of a small fov high res (384x288) thermal camera for android/usb?
Offline Bryn
    • mindsConnected
Re: Looking for a long range android thermal camera
« Reply #1 on: September 28, 2024, 04:35:59 pm »
From a bit of research, the Infiray P2 Pro might be of some use to you (especially when it can be mounted on other devices than just drones).
https://mindsconnected.tech
Small tech forum...
« Reply #2 on: September 28, 2024, 05:20:57 pm »
Thank you it tried the P2 and it has a average not focused fov so the res and focus at distance is very poor
Offline Bryn
    • mindsConnected
« Reply #3 on: September 28, 2024, 05:53:21 pm »
Hmm... well how about the Xinfrared T2 Pro or the HT-301?
Small tech forum...
« Reply #4 on: September 28, 2024, 06:23:59 pm »
Ht-301 I also tried res is good but fov is not, t2 pro lens is good and makes good use of the pixels it has, I wish they made a 384x288 model with the same fov/lens as the t2 pro, that would be a winner!
« Last Edit: September 28, 2024, 06:35:13 pm by michaelnyden »
Offline artag
« Reply #5 on: September 28, 2024, 07:42:39 pm »
TS001 has adjustable focus and a fairly narrow angle - it's intended for longer distances than most. But it's possibly a bit big for a drone, not a tiny cube like the infiray.
« Reply #6 on: September 29, 2024, 01:22:09 am »
Found what I was looking for the xh15 (x3) but it’s not for sale anywhere that I can find.
Offline Win
  • Country: th
« Reply #7 on: April 21, 2026, 11:59:51 am »
Is there any results or information of your work? i am currently interested in doing excatly the same like this. If possible, i would like to discuss more about this. Thank you in advance.
