Oh man I can't thank you enough for discover those serial commands!
I'm adding some thing here you didn't mention.
The RS232 parameter should 115200-8-N-1, flow control doesn't matter.
Here's my original :get returns:
average = 0x001E
background = 0x00FA
baud = 0x01
bias_target = 0xF495
bin_limit = 0x0040
bin_offset = 0x0400
black_hot = 0
brightness = 0x0000
build = 'Mar 29 2006'
button = 0x0600
color = 0x00
color1 = 0x00
color2 = 0x04
command_mask = 0x0006
contrast = 0x0010
date = '221129061733'
deadpix_bg = 1
deadpix_save = 1
drift_factor = 0x0100
edge_thresh = 0x10
emissivity = 0x03B6
err1 = 0xFC85
err_step1 = 0x0010
fine_ad0_trig = 0x1F
fine_ad1_trig = 0x7F
fine_ad2_trig = 0x7F
fine_flags = 0x00DE
fine_frames = 0x001E
fine_timer_delta = 0x003C
fine_timer_end = 0x003C
fine_timer_start = 0x003C
fix_vddr = 1
fixed_mode = 0x04
fixed_offset = 0x0000
fixed_span = 0x0200
flow = 1
fpga_rev = 0x8001
frame = 0x00000892
frame_rate = 0x001E
image_count = 0x02
image_time = 0x00
interp = 1
lag = 0x02
min_span = 0x0080
netd = 43.6044
noise = 4.6884
osd_flags = 0x020F
palette = 0x02
shutter_close = 0x06
shutter_open = 0x06
skip = 0x00
sn = 'ISXS20060410'
tec_timeout = 0x0F
type = 'IR-InSight'
vbias = 0x0F66
vddr = 0x0B2E
verbose_init = 0
version = 'v2.0.1'
Here's my mods and other comments:
bin_limit = 0x0100 --- This is the most important mod, it allows you to see much more details! Don't over-do, or you loss dynamic range.
fine_frames = 0x000F --- Shorten NUC time from 1s to 0.5s, with no bad effect. You can choose a even shorter one, just make sure it do not produce noise pattern.
lag = 0x04 --- Eliminate screen flicker due to AGC. This value too big or too small both will flicker.
verbose_init = 1 --- Show log when boot up.
osd_flags = 0x0000 --- Optional, disable all annoying overlay. Other values have different combination, try yourself.
Other lines --- They have no useful effect, or read only, or set automatically.
:::reset --- Allows you to gracefully reboot the camera.
BTW, This camera performs really well, not like it's advertised "100mk" sensitivity.
Even with f1 lens instead of the original f0.8 one, it shows low delta details well. (With my tweak above)
