In these days I have had the opportunity to test the Hikmicro Analyzer software.
I find that it has a good structure but at the same time it lacks of many basic functions some of which I have already had the opportunity to report to the company support (without receiving any feedback about it...).
Below, what I observed regarding this SW:
1) In "Image Analysis" the "PIP" Display Mode lacks the possibility to resize te PIP frame
2) More, the same "PIP" Display Mode lacks the possibility to remove the "Fusion" effect from the thermal image frame (in order to have a pure thermal image on it).
This aspect also concerns the firmware of the thermal imaging camera (Pocket 2). Even in this enviroment, it would be nice to have the possibility to remove the fusion effect
3) A big problem also affects the three panes on the right side of the Image Analysis window (named "Image Information, Measurements and Parameters respectively). If you try to scroll with the mouse wheel on these windows, if the pointer is above one of the many parameters present, the relative value will inevitably be altered!!!.
You can do enormous damage, even without realizing it, simply by rolling the mouse wheel!
Incredible the fact that none of the development team has noticed this obvious criticality!!!
More, once this damage is done, there's no going back. You have to start from the beginning, reloading the image.
4) Another incredible lack affects the "Report Editing Page". If you try to resize any image, you will lose its aspect ratio!!
There is no way to preserve the image ratio nor to recover it!
It is my opinion that nobody from the development team has ever deeply tested this software...
A software full of gaps and which contrasts with the excellent firmware of the Pocket 2 camera.
Is anyone able to tell me some valid alternative SW dedicated to the analysis of thermal images?
