The objectives of PISEO……
“ Currently, no international performance testing standards have been published. This situation leaves purchasers of such systems with supplied datasheet values that may not always be right or may only provide partial information. This is where Piséo fills the gap, with its independent evaluations and testing of thermal cameras.”
And
“ Establishing an international performance testing standard
In order to characterize the performance of the camera core, Piséo’s experts use their own test protocols, software, and lab equipment, which includes a calibrated HGH black body and climate chamber able to perform tests at ambient temperatures ranging from -20°C (-4°F) up to 100°C (212°F).
There is currently no international standard protocol for thermal camera performance testing available.
After performing our own characterization tests on many devices, analyzing manufacturers’ datasheets and discussing the reasons for the discrepancies between our test results and their published values, it became clear to us that the performance values published were all based on different test protocols. It is, therefore, quite impossible for the purchaser to use the datasheets to select a thermal camera or core based on comparable performance values between products. Therefore, we aim to publish such data based on a fully transparent and consistent testing protocol whatever the product tested.
By doing so, we provide the market with independent, unbiased test results that de facto establish an international performance testing standard for thermal cameras, cores, and sensors. This report contains for the first time a table highlighting the comparison of the main performance indicators between products. using Piséo’s own testing protocol. Manufacturers, integrators and end-users, if you also want to get your thermal camera tested, feel free to drop us a message!”
